I would need some help from you if possible. I have a TVS-871 (I know a bit old it is)... it has always worked well... to be honest I never checked the performance because at the time when I set it all up (few years ago) I needed only the space not the performance. Now I am into high res music files and performance is more important. Anyway, the problem is that when I transfer file from/to the NAS via SMB or AFP from/to my Macbook Pro on my LAN, which is a super fast network running on 802ax protocol, I have slow performance like 60/80 MB/s using Blackmagic Speed Test for example. The HDD's are about 200 MB / s and the RAID about 600 MB/s I can't figure out what's the problem. The NAS is connected directly to my router via 1 GB port. I tried also 2 ports with port trunking but still there is no improvement in performance.
[~] # qcli_storage -t
fio test command for LV layer: /sbin/fio --filename=test_device --direct=0 --rw=read --bs=1M --runtime=15 --name=test-read --ioengine=libaio --iodepth=32 &>/tmp/qcli_storage.log
fio test command for File system: /sbin/fio --filename=test_device/qcli_storage --direct=0 --rw=read --bs=1M --runtime=15 --name=test-read --ioengine=libaio --iodepth=32 --size=128m &>/tmp/qcli_storage.log
Start testing!
Performance test is finished 100.000%...
VolID VolName Pool Mapping_Name Throughput Mount_Path FS_Throughput
1 Downloads 1 /dev/mapper/cachedev2 300.98 MB/s /share/CACHEDEV2_DATA 250.98 MB/s
2 DataVol1 2 /dev/mapper/cachedev3 798.64 MB/s /share/CACHEDEV3_DATA 603.77 MB/s
[~] # qcli_storage -T
fio test command for physical disk: /sbin/fio --filename=test_device --direct=1 --rw=read --bs=1M --runtime=15 --name=test-read --ioengine=libaio --iodepth=32 &>/tmp/qcli_storage.log
fio test command for RAID: /sbin/fio --filename=test_device --direct=0 --rw=read --bs=1M --runtime=15 --name=test-read --ioengine=libaio --iodepth=32 &>/tmp/qcli_storage.log
Start testing!
Enclosure Port Sys_Name Throughput RAID RAID_Type RAID_Throughput Pool
NAS_HOST 1 /dev/sda 527.12 MB/s -- -- -- --
NAS_HOST 2 /dev/sdb 203.13 MB/s /dev/md1 RAID 6 649.85 MB/s 2
NAS_HOST 3 /dev/sdc 200.15 MB/s /dev/md1 RAID 6 649.85 MB/s 2
NAS_HOST 4 /dev/sdd 197.94 MB/s /dev/md1 RAID 6 649.85 MB/s 2
NAS_HOST 5 /dev/sdg 202.18 MB/s /dev/md1 RAID 6 649.85 MB/s 2
NAS_HOST 6 /dev/sdh 198.67 MB/s /dev/md1 RAID 6 649.85 MB/s 2
NAS_HOST 7 /dev/sde 197.50 MB/s /dev/md1 RAID 6 649.85 MB/s 2
NAS_HOST 8 /dev/sdf 201.67 MB/s /dev/md1 RAID 6 649.85 MB/s 2
EXDR#1 1 /dev/sdj 170.77 MB/s /dev/md2 RAID 6 296.21 MB/s 1
EXDR#1 2 /dev/sdm 170.06 MB/s /dev/md2 RAID 6 296.21 MB/s 1
EXDR#1 3 /dev/sdn 168.73 MB/s /dev/md2 RAID 6 296.21 MB/s 1
EXDR#1 4 /dev/sdk 214.12 MB/s /dev/md2 RAID 6 296.21 MB/s 1
EXDR#1 5 /dev/sdl 166.00 MB/s /dev/md2 RAID 6 296.21 MB/s 1
