As of 5.0.x, Qsync keeps restoring deleted files and folders back to my PC randomly. It also happens after I renamed my files and folders, it even restoring them back with the older names (sometimes appears as conflict 0) and replacing my files back to old
Is the conflict policy "Replace files on the NAS with local files" correct for this case? I had this option for years to not show conflict popup. "Do not remove any file on the NAS during synchronization" is unchecked
Honestly, I never had this issue on previous versions 4.x.x until 5.0.x, I have been using Qsync for years. Only one PC being synced locally via ethernet only, so nothing are slowed down
My Qnap is TS251+. Everything are updated
This is what it does
Qsync keeps restoring deleted/renamed files and folders back to my PC
Re: Qsync keeps restoring deleted/renamed files and folders back to my PC
It is still happening
Anyone?
Anyone?
Contact qnap support via ticket
Any progress on a resolution or explanation?
[Main Server]
QNAP TS-872X7 (QuTS)
PCIe Gen3 x4: QNAP QM2-2P-344 with 2 x 2TB XPG SX8200 Pro NVMe
8 x WD102KFBX 10TB Red Pro, RAID6
[Backup]
TS-128A
18TB WD181KFGX Red Pro
[Backup]
TS-128A
