in our Czech home, we have one QNAP NAS which is used as a file-sharing server. I use Linux and don't have a problem with saving files through NFS even if contains diacritics. My girlfriend uses Windows 10 with Czech localization. Shared dirs are mounted via SMB protocol. But if she saves some files containing diacritics then these files have broken names because diacritic chars are substituted by � signs and have zero bytes size. Next strange thing is that all files have metafile with these name template: <file_name>:Zone.identifier. What I read this is because W10 has a problem with saving files and this Zone.identifier is some sync metafile. I verified the file encoding type and it's saved in UTF-8 coding.
I checked QNAP setting and tried General Settings > Codepage to set to English or Slavic/Latin2 but nothing helped.
The example of the file's name is attached to this question.
Can I ask you for help?
Additional info:
* FIles is not possible to remove from Linux. Just from W10 or from NAS.
Files from Windows 10 have meta files with extension Zone.Identifier
Re: Files from Windows 10 have meta files with extension Zone.Identifier
Too little information is given.
NAS model?
firmware version?
SMB configuration on the NAS?
NFS configuration on the NAS?
regional settings on Windows client?
regional settings on Linux client?
NFS mount options on the Linux client?
NAS model?
firmware version?
Where are these filenames displayed? On the NAS filesystem? On the Windows client? On the Linux client?
This is an ADS (Alternate Data Stream) used by Windows on NTFS to store metadata. Zone.Identifier is created by Microsoft (and maybe others, IDK) web browsers when downloading files from the internet or untrusted networks. The default SMB configuration on current QNAP systems stores ADSes in a hidden directory at the top of the shared folder - they should not appear alongside the file to which it belongs.Next strange thing is that all files have metafile with these name template: <file_name>:Zone.identifier.
Where?I verified the file encoding type and it's saved in UTF-8 coding.
Where was the screenshot taken?The example of the file's name is attached to this question.
@Mousetick thank you for your response. You're right - my information was not complete.
QNAP:
Regional setting on Windows 10:
Regional setting on Linux:
NFS mount options on the Linux client:
List files from Linux: I cannot see the appropriate file size and name created on Windows 10.
List files from Windows 10: I cannot see the appropriate file name created on the Linux (file name: příliš_žluťoučký_kůň_úpěl_ďábelské_ódy_walda.txt)
List files from the QNAP: I cannot see the appropriate file name created on Windows 10.
How I verified encoding used on Windows 10: I created a text file in Notepad and saved it. The saving dialog asked me which encoding should be used:
QNAP:
- Moded: TS-253A
- Firmware: 4.5.3.1652
- SMB configuration:
[~] # cat /etc/sm smart_selftest_blacklist/ smb.conf [~] # cat /etc/smb.conf [global] passdb backend = smbpasswd workgroup = WORKGROUP security = USER server string = NAS Server encrypt passwords = Yes username level = 0 map to guest = Never max log size = 10 socket options = TCP_NODELAY SO_KEEPALIVE os level = 20 preferred master = no dns proxy = No smb passwd file=/etc/config/smbpasswd username map = /etc/config/smbusers guest account = guest directory mask = 0777 create mask = 0777 oplocks = yes locking = yes disable spoolss = no load printers = yes veto files = /.AppleDB/.AppleDouble/.AppleDesktop/:2eDS_Store/Network Trash Folder/Temporary Items/TheVolumeSettingsFolder/.@__thumb/.@__desc/:2e*/.@__qini/.Qsync/.@upload_cache/.qsync/.qsync_sn/.@qsys/.streams/.digest/ delete veto files = yes map archive = no map system = no map hidden = no map read only = no deadtime = 10 restrict anonymous = 2 server role = auto use sendfile = yes unix extensions = no store dos attributes = yes client ntlmv2 auth = yes dos filetime resolution = no kerberos method = secrets and keytab follow symlinks = yes wide links = yes force unknown acl user = yes template homedir = /share/homes/DOMAIN=%D/%U inherit acls = no domain logons = no min receivefile size = 256 case sensitive = auto domain master = auto local master = no enhance acl v1 = yes remove everyone = no conn log = no kernel oplocks = no min protocol = SMB3_00 smb2 leases = yes durable handles = yes kernel share modes = no posix locking = no lock directory = /share/CACHEDEV1_DATA/.samba/lock state directory = /share/CACHEDEV1_DATA/.samba/state cache directory = /share/CACHEDEV1_DATA/.samba/cache invalid users = guest printcap cache time = 0 acl allow execute always = yes server signing = disabled streams_depot:delete_lost = yes streams_depot:check_valid = no fruit:nfs_aces = no fruit:veto_appledouble = no winbind expand groups = 1 server schannel = yes winbind scan trusted domains = no winbind max clients = 2000 winbind max domain connections = 1 pid directory = /var/lock wins support = no host msdfs = yes printcap name = /etc/printcap printing = cups show add printer wizard = no winbind enum groups = Yes winbind enum users = Yes dos charset = ISO8859-2 vfs objects = shadow_copy2 catia fruit qnap_macea streams_depot server kernel smbd support = no [Web] comment = System default share path = /share/CACHEDEV1_DATA/Web browsable = yes oplocks = yes ftp write only = no recycle bin = yes recycle bin administrators only = no qbox = no timemachine = no public = yes invalid users = "guest" read list = write list = "admin" valid users = "root","admin" q type = 0 inherit permissions = yes shadow:showprevious = yes shadow:snapdir = /share/CACHEDEV1_DATA/_.share/Web/.snapshot shadow:basedir = /share/CACHEDEV1_DATA/Web shadow:sort = desc shadow:format = @GMT-%Y.%m.%d-%H:%M:%S smb encrypt = disabled create time = 2020:10:26:23:01:22:63 mangled names = yes hide unreadable = no access based share enum = no strict sync = no strict allocate = yes streams_depot:check_valid = yes [Public] comment = System default share path = /share/CACHEDEV1_DATA/Public browsable = yes oplocks = yes ftp write only = no recycle bin = yes recycle bin administrators only = no qbox = no timemachine = no public = yes invalid users = "guest" read list = "hp_scan" write list = "admin" valid users = "root","admin","hp_scan" q type = 0 inherit permissions = yes shadow:showprevious = yes shadow:snapdir = /share/CACHEDEV1_DATA/_.share/Public/.snapshot shadow:basedir = /share/CACHEDEV1_DATA/Public shadow:sort = desc shadow:format = @GMT-%Y.%m.%d-%H:%M:%S smb encrypt = disabled create time = 2020:10:26:23:01:24:05 mangled names = yes hide unreadable = no access based share enum = no strict sync = no strict allocate = yes streams_depot:check_valid = yes [homes] comment = System default share path = /share/CACHEDEV1_DATA/homes browsable = yes oplocks = yes ftp write only = no recycle bin = yes recycle bin administrators only = no qbox = no timemachine = no public = yes invalid users = read list = write list = "admin" valid users = "root","admin" q type = 0 inherit permissions = yes shadow:showprevious = yes shadow:snapdir = /share/CACHEDEV1_DATA/_.share/homes/.snapshot shadow:basedir = /share/CACHEDEV1_DATA/homes shadow:sort = desc shadow:format = @GMT-%Y.%m.%d-%H:%M:%S smb encrypt = disabled create time = 2020:10:26:23:03:20:12 mangled names = yes hide unreadable = no access based share enum = no strict sync = no [__DATA] comment = path = /share/CACHEDEV1_DATA/__DATA browsable = yes oplocks = yes ftp write only = no recycle bin = yes recycle bin administrators only = no qbox = no timemachine = no public = yes invalid users = read list = write list = @"administrators","admin","waldauf","terka",@"everyone","guest" valid users = "root",@"administrators","admin","waldauf","terka",@"everyone","guest" q type = 0 inherit permissions = yes shadow:showprevious = yes shadow:snapdir = /share/CACHEDEV1_DATA/_.share/__DATA/.snapshot shadow:basedir = /share/CACHEDEV1_DATA/__DATA shadow:sort = desc shadow:format = @GMT-%Y.%m.%d-%H:%M:%S smb encrypt = disabled create time = 2020:10:26:23:16:07:12 mangled names = yes hide unreadable = no access based share enum = no strict sync = no strict allocate = yes streams_depot:check_valid = yes [__FOTO] comment = path = /share/CACHEDEV1_DATA/__FOTO browsable = yes oplocks = yes ftp write only = no recycle bin = yes recycle bin administrators only = no qbox = no timemachine = no public = yes invalid users = "guest" read list = write list = @"administrators","admin","waldauf","terka",@"everyone" valid users = "root",@"administrators","admin","waldauf","terka",@"everyone" q type = 0 inherit permissions = yes shadow:showprevious = yes shadow:snapdir = /share/CACHEDEV1_DATA/_.share/__FOTO/.snapshot shadow:basedir = /share/CACHEDEV1_DATA/__FOTO shadow:sort = desc shadow:format = @GMT-%Y.%m.%d-%H:%M:%S smb encrypt = disabled create time = 2020:10:26:23:16:43:47 mangled names = yes hide unreadable = no access based share enum = no strict sync = no strict allocate = yes streams_depot:check_valid = yes [__FOOBAR1] comment = path = /share/CACHEDEV1_DATA/__FOOBAR1 browsable = yes oplocks = yes ftp write only = no recycle bin = yes recycle bin administrators only = no qbox = no timemachine = no public = yes invalid users = "guest" read list = write list = @"administrators","admin","waldauf","terka",@"everyone" valid users = "root",@"administrators","admin","waldauf","terka",@"everyone" q type = 0 inherit permissions = yes shadow:showprevious = yes shadow:snapdir = /share/CACHEDEV1_DATA/_.share/__FOOBAR1/.snapshot shadow:basedir = /share/CACHEDEV1_DATA/__FOOBAR1 shadow:sort = desc shadow:format = @GMT-%Y.%m.%d-%H:%M:%S smb encrypt = disabled create time = 2020:10:26:23:17:16:47 mangled names = yes hide unreadable = no access based share enum = no strict sync = no hosts allow = strict allocate = yes streams_depot:check_valid = yes [__GIT] comment = path = /share/CACHEDEV1_DATA/__GIT browsable = yes oplocks = yes ftp write only = no recycle bin = yes recycle bin administrators only = no qbox = no timemachine = no public = yes invalid users = "guest" read list = write list = @"administrators","admin","waldauf" valid users = "root",@"administrators","admin","waldauf" q type = 0 inherit permissions = yes shadow:showprevious = yes shadow:snapdir = /share/CACHEDEV1_DATA/_.share/__GIT/.snapshot shadow:basedir = /share/CACHEDEV1_DATA/__GIT shadow:sort = desc shadow:format = @GMT-%Y.%m.%d-%H:%M:%S smb encrypt = disabled create time = 2020:10:26:23:17:55:61 mangled names = yes hide unreadable = no access based share enum = no strict sync = no strict allocate = yes streams_depot:check_valid = yes [Container] comment = Container Station path = /share/CACHEDEV1_DATA/Container browsable = yes oplocks = yes ftp write only = no recycle bin = no recycle bin administrators only = no qbox = no timemachine = no public = yes invalid users = "guest" read list = write list = @"administrators","admin" valid users = "root",@"administrators","admin" q type = 0 inherit permissions = yes shadow:showprevious = yes shadow:snapdir = /share/CACHEDEV1_DATA/_.share/Container/.snapshot shadow:basedir = /share/CACHEDEV1_DATA/Container shadow:sort = desc shadow:format = @GMT-%Y.%m.%d-%H:%M:%S smb encrypt = disabled create time = 2020:10:26:23:58:17:26 mangled names = yes hide unreadable = no access based share enum = no strict sync = no strict allocate = yes streams_depot:check_valid = yes [__FOOBAR2] comment = path = /share/CACHEDEV1_DATA/__FOOBAR2 browsable = yes oplocks = yes ftp write only = no recycle bin = yes recycle bin administrators only = no qbox = no timemachine = no public = yes invalid users = "guest" read list = write list = @"administrators","admin","waldauf","terka",@"everyone" valid users = "root",@"administrators","admin","waldauf","terka",@"everyone" q type = 0 inherit permissions = yes shadow:showprevious = yes shadow:snapdir = /share/CACHEDEV1_DATA/_.share/__FOOBAR2/.snapshot shadow:basedir = /share/CACHEDEV1_DATA/__FOOBAR2 shadow:sort = desc shadow:format = @GMT-%Y.%m.%d-%H:%M:%S smb encrypt = disabled create time = 2020:10:27:00:29:43:26 mangled names = yes hide unreadable = no access based share enum = no strict sync = no strict allocate = yes streams_depot:check_valid = yes [printers] use client driver = yes writable = no browsable = no printable = yes guest ok = yes path = /var/spool/smb [HP_Scan] comment = path = /share/CACHEDEV1_DATA/HP_Scan browsable = yes oplocks = yes ftp write only = no recycle bin = yes recycle bin administrators only = no qbox = no timemachine = no public = yes invalid users = read list = write list = @"administrators","admin","guest","waldauf","terka","hp_scan",@"everyone" valid users = "root",@"administrators","admin","guest","waldauf","terka","hp_scan",@"everyone" q type = 0 inherit permissions = yes shadow:showprevious = yes shadow:snapdir = /share/CACHEDEV1_DATA/_.share/HP_Scan/.snapshot shadow:basedir = /share/CACHEDEV1_DATA/HP_Scan shadow:sort = desc shadow:format = @GMT-%Y.%m.%d-%H:%M:%S smb encrypt = mandatory create time = 2021:01:10:17:39:41:43 strict allocate = yes streams_depot:check_valid = yes mangled names = yes hide unreadable = no access based share enum = no strict sync = yes hosts allow = [home] comment = Home path = %H browsable = yes oplocks = yes ftp write only = no inherit permissions = yes invalid users = guest writable = yes read list = "%u" write list = "%u" valid users = "%u" root preexec = /sbin/create_home -u '%q' smb encrypt = disabled create time = 2020:10:26:23:03:20:12 shadow:snapdir = /share/CACHEDEV1_DATA/homes/../_.share/homes/.snapshot shadow:basedir = %H shadow:sort = desc shadow:format = @GMT-%Y.%m.%d-%H:%M:%S
- NFS configuration
[/etc/config] # cat nfssetting [Global] Version = 4.5.1 squash_check = 1 [Access] /share/CACHEDEV1_DATA/Public = FALSE /share/CACHEDEV1_DATA/__FOOBAR1 = TRUE /share/CACHEDEV1_DATA/__FOOBAR2 = TRUE /share/CACHEDEV1_DATA/__GIT = TRUE /share/CACHEDEV1_DATA/__FOTO = TRUE /share/CACHEDEV1_DATA/__DATA = TRUE [AllowIP] /share/CACHEDEV1_DATA/Public = * /share/CACHEDEV1_DATA/__FOOBAR1 = * /share/CACHEDEV1_DATA/__FOOBAR2 = * /share/CACHEDEV1_DATA/__GIT = * /share/CACHEDEV1_DATA/__FOTO = * /share/CACHEDEV1_DATA/__DATA = * [Auth_sys] /share/CACHEDEV1_DATA/Public = 1 [Auth_krb5] /share/CACHEDEV1_DATA/Public = 0 [Auth_krb5i] /share/CACHEDEV1_DATA/Public = 0 [Auth_krb5p] /share/CACHEDEV1_DATA/Public = 0 [Permission] /share/CACHEDEV1_DATA/Public = rw /share/CACHEDEV1_DATA/__FOOBAR1 = rw /share/CACHEDEV1_DATA/__FOOBAR2 = rw /share/CACHEDEV1_DATA/__GIT = rw /share/CACHEDEV1_DATA/__FOTO = rw /share/CACHEDEV1_DATA/__DATA = rw [Sync_option] /share/CACHEDEV1_DATA/Public = 0 [Wdelay_option] /share/CACHEDEV1_DATA/Public = 1 [Secure_option] /share/CACHEDEV1_DATA/Public = 0 [SquashOption] /share/CACHEDEV1_DATA/Public = no_root_squash /share/CACHEDEV1_DATA/__FOOBAR1 = no_root_squash /share/CACHEDEV1_DATA/__FOOBAR2 = no_root_squash /share/CACHEDEV1_DATA/__GIT = no_root_squash /share/CACHEDEV1_DATA/__FOTO = no_root_squash /share/CACHEDEV1_DATA/__DATA = no_root_squash [AnonUID] /share/CACHEDEV1_DATA/Public = 65534 /share/CACHEDEV1_DATA/__FOOBAR1 = 65534 /share/CACHEDEV1_DATA/__FOOBAR2 = 65534 /share/CACHEDEV1_DATA/__GIT = 65534 /share/CACHEDEV1_DATA/__FOTO = 65534 /share/CACHEDEV1_DATA/__DATA = 65534 [AnonGID] /share/CACHEDEV1_DATA/Public = 65534 /share/CACHEDEV1_DATA/__FOOBAR1 = 65534 /share/CACHEDEV1_DATA/__FOOBAR2 = 65534 /share/CACHEDEV1_DATA/__GIT = 65534 /share/CACHEDEV1_DATA/__FOTO = 65534 /share/CACHEDEV1_DATA/__DATA = 65534 [SubtreeCheck] /share/CACHEDEV1_DATA/Public = no_subtree_check [Is_modified] /share/CACHEDEV1_DATA/Public = 0 /share/CACHEDEV1_DATA/__FOOBAR1 = 0 /share/CACHEDEV1_DATA/__FOTO = 0 /share/CACHEDEV1_DATA/__DATA = 0 /share/CACHEDEV1_DATA/__GIT = 0 /share/CACHEDEV1_DATA/__FOOBAR2 = 0
- Regional and Language Options: Czech Republic
- Current format: Czech
❯ locale
LANG=en_US.UTF-8
LC_CTYPE="en_US.UTF-8"
LC_NUMERIC="en_US.UTF-8"
LC_TIME=en_US.UTF-8
LC_COLLATE=C
LC_MONETARY="en_US.UTF-8"
LC_MESSAGES="en_US.UTF-8"
LC_PAPER="en_US.UTF-8"
LC_NAME="en_US.UTF-8"
LC_ADDRESS="en_US.UTF-8"
LC_TELEPHONE="en_US.UTF-8"
LC_MEASUREMENT="en_US.UTF-8"
LC_IDENTIFICATION="en_US.UTF-8"
LC_ALL=
otesanek:/__FOOBAR1 on /home/waldauf/__PERSONAL__/__OTESANEK/foobar1 type nfs4 (rw,relatime,vers=4.2,rsize=524288,wsize=524288,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.111.5,local_lock=none,addr=192.168.111.2)
otesanek:/__FOOBAR2 on /home/waldauf/__PERSONAL__/__OTESANEK/foobar2 type nfs4 (rw,relatime,vers=4.2,rsize=524288,wsize=524288,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.111.5,local_lock=none,addr=192.168.111.2)
otesanek:/__FOTO on /home/waldauf/__PERSONAL__/__OTESANEK/foto type nfs4 (rw,relatime,vers=4.2,rsize=524288,wsize=524288,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.111.5,local_lock=none,addr=192.168.111.2)
otesanek:/__DATA on /home/waldauf/__PERSONAL__/__OTESANEK/data type nfs4 (rw,relatime,vers=4.2,rsize=524288,wsize=524288,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.111.5,local_lock=none,addr=192.168.111.2)
Much better with plenty of info, thanks.
How do those files look in Windows Explorer?
Looks to me like the issue is on the Windows side. Do your tests only using Notepad and Windows Explorer, nothing else. And test from scratch, don't use existing files.
If I create a file on Windows 10 named 'příliš_žluťoučký_kůň_úpěl_ďábelské_ódy_walda.txt' and then copy it to the NAS (Linux) via SMB, it shows up correctly on the Linux side. My Windows regional settings and Linux Samba settings are not the same as yours, so that doesn't prove anything, but as long as Unicode UTF-8 is used on both sides, it should work.
No idea about the file size issue via NFS. It may be related to the filename encoding issue, or it may be something else.
That doesn't look like a native Windows app. What is it?
This setting applies to the text encoding of the file's contents. They have no effect at all on the filename's encoding. So this verification is irrelevant regarding your problem.How I verified encoding used on Windows 10: I created a text file in Notepad and saved it. The saving dialog asked me which encoding should be used:
That's the Total Commander. In Windows Explorer, it looks identical.
I tested it by using an existing file or create a new one (a TXT file) and always with the same result. I always had used Windows Explorer to copy files on SMB disk.Mousetick wrote: ↑Sun May 02, 2021 10:27 pmThis setting applies to the text encoding of the file's contents. They have no effect at all on the filename's encoding. So this verification is irrelevant regarding your problem.waldauf wrote: How I verified encoding used on Windows 10: I created a text file in Notepad and saved it. The saving dialog asked me which encoding should be used:
Damn, you're a lucky boy. I have tested Windows 10 with English localization and still the same result. I don't know what to do more. :/Mousetick wrote: ↑Sun May 02, 2021 10:27 pm If I create a file on Windows 10 named 'příliš_žluťoučký_kůň_úpěl_ďábelské_ódy_walda.txt' and then copy it to the NAS (Linux) via SMB, it shows up correctly on the Linux side. My Windows regional settings and Linux Samba settings are not the same as yours, so that doesn't prove anything, but as long as Unicode UTF-8 is used on both sides, it should work.
I appreciate the time you've given me to help me, thank you.
I tested how looks dos charset in the /etc/config/smb.conf for different non-Unicode set in Control Panel > Setting > Codepage:
I tried to set dos charset = UTF-8. But it didn't help.
[~] # grep charset /etc/config/smb.conf
# Western Europe / Latin 1
dos charset = ISO8859-1
# English
dos charset = ASCII
# Slavic / Latin 2
I don't know if I'm lucky or not, I think this is just how it's supposed to work so I'm not surprised it does.
The next thing you may want to try is run Samba on your Linux box and test between Windows and your Linux box. That should tell you if the issue is on QNAP or Windows side.
If it's on Windows, you'll find better help from the Czech Windows or Linux communities than over here.
This configuration setting is for legacy clients (prior to Windows XP or thereabouts) that don't support Unicode. I don't think it matters at all in your case.
I create SMB share from my Linux to QNAP dir which I have mounted via NTFS. Everything works fine. The file's name is alright, size too. I can read file content.Mousetick wrote: ↑Sun May 02, 2021 11:18 pm The next thing you may want to try is to run Samba on your Linux box and test between Windows and your Linux box. That should tell you if the issue is on QNAP or Windows side.
Again thx to @Mousetick for your help.
It seems that the problem is definitely on the Windows 10 side. I leave this issue open upon I find out where the problem is.
