Guest access doesn't work
FTP Server, File Server, DDNS, SAMBA, AFP, NFS
pixelpelx
Post by pixelpelx »
From a recent update my QNAP shares don't work with guest access from other devices. I have @everyone enabled https://www.dropbox.com/s/mxxs1z7go6urd ... 4.png?dl=0 and smb.conf params looks as following:
[global]
guest account = guest
[Media]
comment =
path = /share/CACHEDEV2_DATA/Media
browsable = yes
oplocks = yes
ftp write only = no
recycle bin = yes
recycle bin administrators only = no
qbox = no
timemachine = no
public = yes
invalid users = "ftp"
guest ok = yes
read list = "guest",@"everyone"
write list = @"administrators","admin","dlna","media"
valid users = "root",@"administrators","admin","dlna","media","guest",@"everyone"
inherit permissions = yes
shadow:showprevious = yes
shadow:snapdir = /share/CACHEDEV2_DATA/_.share/Media/.snapshot
shadow:basedir = /share/CACHEDEV2_DATA/Media
shadow:sort = desc
shadow:format = @GMT-%Y.%m.%d-%H:%M:%S
smb encrypt = disabled
create time = 2020:08:27:22:27:52:98
strict allocate = yes
streams_depot:check_valid = yes
mangled names = yes
hide unreadable = no
access based share enum = no
admin users = @"everyone"
admin only =
Could you help to setup a proper guest access please?
Moogle Stiltzkin
Contact:
Re: Guest access doesn't work
Post by Moogle Stiltzkin »
for qnap, you go to qts, settings > shares, then for the share you toggle guess access enabled.
for client devices like windows 10, make sure network discovery is enabled
if they still don't have access, you can try check in qts if changing minimum smb to smb1 does anything? if not, you can set it back to smb 2.1 or smb3.
NAS
Network
Resources
pixelpelx
Post by pixelpelx »
Moogle Stiltzkin wrote: Sun May 02, 2021 4:41 am for qnap, you go to qts, settings > shares, then for the share you toggle guess access enabled.
Thank you, I tried all these, however with no luck. Still QNAP is discoverable through SMB protocol, however no guest access is allowed.
Return to “File Sharing”
