IN my NAS I have the PuTTy panel open with the prompt at [~] #
I want to find the dir where 7z.log file is and then open that file it it is there.
How to do please?
EDIT::
Well I managed to find a kong command which took me to {/usr/local/sbin] and after ls, it shows these files..
I am looking for the pwd that may be there somewhere after Qlocker. They say 7z.log but that file is not here. Could it be somewhere else?
7z* app_route_monitor* clamd@ dcraw* flv_convertd* iscsiadm* JMFwUpdate* lpmove* mount.fuse-ext2@ nc_tool@ qpkg_service* qulog-archive@ restart_copy* syslog_maild*
7z.bak* aumix* cnid_dbd* debugfs@ ftptop* iscsid* jpegtran* lpoptions* msgfmt@ notify@ qrencode* qulogd@ rsyslogd@ _thttpd_*
7z.orig* blkid@ cnid_metad* debugfs_64* gen_2sv_qrcode.sh* iscsi_logd* jq* lpq* natpmpc-static* proftpd* qrm* qulogdb@ smbtools* unrar*
7z.so* blkid_64* Codecs/ dhcpd* gifinter* iscsi_util* losetup* lpr* nc@ qboostd@ qsh* qulog-session@ sound_ctl* unzip*
afpd* brctl* composite@ djpeg* gifrsize* isns_cd* lp* lprm* ncd@ qboost_util@ qsh-static* radclient@ speaker.sh* vdd_control*
apcaccess* cancel* convert@ dumpe2fs@ identify@ isns_cli* lpadmin* lpstat* ncdb@ qpkg_cli* qsyncsrv_util* radiusd@ static_defender* wfm_thttpd@
apcupsd* cjpeg* dbd* dumpe2fs_64* ImR_all* jhead* lpinfo* mcelog* ncloud@ qpkgd* Qthttpd@ radtest@ stx_ihm* zip*
EDIT 2 I have finally found where the file is..
[/share/CACHEDEV1_DATA/.qpkg/MalwareRemover] # ls
7z.log common.sh* MalwareRemover_scan.sh* modules/ www/
backupfolder/ MalwareRemover@ MalwareRemover.sh* Upgrade.sh*
