Sharing folder from one NAS to another NAS on same LAN
FTP Server, File Server, DDNS, SAMBA, AFP, NFS
scarng
Post by scarng »
I have a TS-253D as my main NAS and a TS-251+ as my secondary.
I set up Plex on the TS-253D as my main media server and then mounted the TS-251+ as my music library. The other day the Music library was no longer mounted. It works when I issue this command via a SSH session:
mount.cifs //172.16.0.15/Multimedia/Music /share/Multimedia/Music -o rw
The problem is every few weeks or I suspect after each firmware update I lose the mount. How do I share a folder from one NAS to another NAS on the same LAN, permanently?
dolbyman
Re: Sharing folder from one NAS to another NAS on same LAN
Post by dolbyman »
how a bout mount via filestation?
I have my 419 mounted to my 951 and never lost it through updates
scarng
Post by scarng »
How to select the NAS that has the music folder from the NAS that is the plex? I can't figure that out.
dolbyman
Post by dolbyman »
In filestation, click on "remote mount" (top right) and then go through the CIFS/SMB mount of the Hybridmount popup, pretty much self explanatory
scarng
Post by scarng »
[SOLVED] Using Filestation 5 - I had to install Hybrid Mount. But I created the mount and PLEX is not indexing the remote folder. Sweet, Thanks.
dolbyman
Post by dolbyman »
not or now ?
scarng
Post by scarng »
oops, typo it IS DONE indexing. Woohoo. My MUSIC Is NOW accessible from all my devices. Thank you.
dolbyman
Post by dolbyman »
scarng wrote: Thu May 27, 2021 2:33 am My MUSIC Is not accessible from all my devices.
I guess the same typo again .. now instead of not .. right ?
scarng
Post by scarng »
I fixed it and NOW happy.
dolbyman
Post by dolbyman »
perfect
Return to “File Sharing”
