Unable to restore system default folders
FTP Server, File Server, DDNS, SAMBA, AFP, NFS
CodeMonkeyIA
Post by CodeMonkeyIA »
I recently had to rebuild my qnap(delete and recreate storage pool and volume)
The only folders that were recreated where home and Public. When I go into the Share Folder and try to recrate the system default folders. I get the attached error.
I know I can manually recreate them just wondering why this isn't working as designed.
CodeMonkeyIA
Re: Unable to restore system default folders
Nevermind. Figured it out. When I was installing some apps, I got a promt to enable Multimedia services. The folders showed up properly after that
Return to “File Sharing”
