I am not quite sure if I should post my inquiry here or in the Web Server forum.
We are running a web app, FrontAccounting, inside our NAS (TVS-673, running on firmware 4.5.3.1697). Recently, we have upgraded ALL of our disks from 4TB to 6TB, so we have 4 6TB disks inside.
Suddenly, some parts of the web app stopped working. I have enabled the debugging of the app, and found an error stating;
Cannot redeclare get_po() (previously declared in /share/CACHEDEV1_DATA/Web/fa/purchasing/includes/db/po_db.inc:163) in /share/CACHEDEV1_DATA/Web/fa/reporting/rep209.php on line 34
I have checked the FrontAccounting forums but there are nothing that points out to this issue.
Did we make a mistake on the rebuilding process (we replaced the drive one by one, waiting for it to rebuild the RAID 10 before placing in another)? Can I clear out this cachedev folder?
I am quite inexperienced with this errors. I do hope someone can help us out with this. Thanks!
CACHEDEV error after replacing ALL disks inside NAS
Re: CACHEDEV error after replacing ALL disks inside NAS
cachedev is were all userdata is stored ...deleting that would delete all userdata and break your nas
best would be to contact a system integrator or expert in this field, debugging the code at the line given
also make sure that no part of the nas is web exposed...a bad idea
