on Quts,
there is one shared folder containing many files and folders.
How do i share one of the subfolders?
Is there any way ?
thx
bancha
QuTS: how to to share a subfolder
Re: QuTS: how to to share a subfolder
can't you just adjust the drivemount?
mount:
\\nasiporname\share\subfolder(\asmanysubfoldersdeepasyou want)
mount:
I want to assign different access rights to differnet users on the subfolders.
that info was not given before
you can enable advanced acl in the share to manage different permissions
Ah OK, I will try and play with it.
THX DM.
THX DM.
I cant find the settings for advanced ACL or folder permissions ....
shown here
https://www.qnap.com/en-in/how-to/tutor ... -with-hbs3
possible that quts has it set by default ..but check
Its done in this way:
https://www.qnap.com/de-de/how-to/faq/a ... smb-access
