Qsync renames files and folders arbitrarily appending with _conflict_(0)
FTP Server, File Server, DDNS, SAMBA, AFP, NFS
surferkhaled
Post by surferkhaled »
Anyone seen this behaviour before?
Files just start being renamed as you can see below appended with _conflict_(0) - no idea what is causing this, but it's happening on only one machine , a macbook with OS Catalina.
in some cases a new folder is created with the _conflict_(0) appended and then data seems to be distributed between the two folders, so it's a nightmare to consolidate and make sure all the files are put back into the original folder.
I've removed the NAS and disabled qsync until I can figure out what this thing is trying to do.
khaled@khaled Lang % ls -al
total 16
drwxr-xr-x@ 32 khaled  staff  1024 Aug 25 16:54 .
drwxr-xr-x@ 25 khaled  staff   800 Aug 25 16:45 ..
-rw-r--r--@  1 khaled  staff  6148 Aug 25 16:54 .DS_Store
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 ar-SA_conflict_(0)
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 cs-CZ
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 da-DK_conflict_(0)
drwxr-xr-x@  4 khaled  staff   128 Aug 24 00:02 de-DE
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 el-GR
drwxr-xr-x@  4 khaled  staff   128 Aug 24 00:02 en-US
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 es-ES
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 fi-FI_conflict_(0)
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 fr-FR_conflict_(0)
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 he-IL_conflict_(0)
drwxr-xr-x@  4 khaled  staff   128 Aug 24 00:02 hr-HR
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 hu-HU_conflict_(0)
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 it-IT_conflict_(0)
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 ja-JP_conflict_(0)
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 ko-KR
drwxr-xr-x@  4 khaled  staff   128 Aug 24 00:02 nb-NO
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 nl-NL_conflict_(0)
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 pl-PL
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 pt-BR
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 pt-PT
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 ro-RO
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 ru-RU
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 sk-SK
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 sl-SI
drwxr-xr-x@  4 khaled  staff   128 Aug 24 00:02 sv-SE
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 th-TH
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 tr-TR
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 zh-CN_conflict_(0)
drwxr-xr-x@  4 khaled  staff   128 Aug 25 16:47 zh-TW_conflict_(0)
dolbyman
Re: Qsync renames files and folders arbitrarily appending with _conflict_(0)
Post by dolbyman »
download the debug report
(3 dots in hbs 3 top right) and check the qsync logs
surferkhaled
Thanks for the quick reply Sir.
Seeing a lot of the following entries in the log:
25.08.21 16:53:43 [QNFileSystemManager-startSync] Pair(Qsync): startSync (isFullSync: NO)
25.08.21 16:53:44 [QNFileSystemManager-startSync] Pair(Qsync): Call startSyncConn
25.08.21 16:53:44 [QNFileSystemManager-createStartSyncConn] Pair(Qsync): Call
25.08.21 16:53:44 [QNFileSystemManager-createStartSyncConn] Pair(Qsync): Create new one, success:YES
25.08.21 16:53:44 [QNFileSystemManager-startSyncConn] Pair(Qsync): start sync conn
25.08.21 16:53:44 [QNFileSystemManager-startSyncConn] Pair(Qsync): abort sync conn (pause/stop)
25.08.21 16:53:45 [QNFileSystemManager-startSyncConn] Pair(Qsync): start compare (check diffence files), 408
25.08.21 16:53:45 [QNFsDictionary-setObject] QNFileInfo path: /NAS Downloads/30 Ambient Sounds - Travel & Films_conflict_(0), folder is not empty, can not replace to file
25.08.21 16:53:48 [QNFileSystemManager-startSyncConn] Pair(Qsync): start compare (skip files), filter files: 0, smart delete files: 0
25.08.21 16:53:48 [QNFileSystemManager-startSyncConn] Pair(Qsync): start compare (case conflict files), 40
25.08.21 16:53:48 [QNFileSystemManager-startSyncConn] Pair(Qsync): finish sync conn, diffConn=79
25.08.21 16:53:49 [QNFsDictionary-setObject] QNFileInfo path: /Work/CAB 2019_conflict_(0), folder is not empty, can not replace to file
25.08.21 16:53:56 [QNFsDictionary-setObject] QNFileInfo path: /NAS Documents/.../.../.../Swiss_conflict_(0), folder is not empty, can not replace to file
25.08.21 16:53:59 [QNFsDictionary-setObject] QNFileInfo path: /NAS Documents/Courses/Chapter2_conflict_(0), folder is not empty, can not replace to file
25.08.21 16:54:04 [QNFsDictionary-setObject] QNFileInfo path: /Work/Anomali/Research_conflict_(0), folder is not empty, can not replace to file
25.08.21 16:54:06 [QNFsDictionary-setObject] QNFileInfo path: /NAS Downloads/From Green USB/Intel_VGA_25.20.100.6471_RS5_20181228/Lang/hu-HU_conflict_(0), folder is not empty, can not replace to file
25.08.21 16:54:30 [QNFsDictionary-setObject] QNFileInfo path: /NAS Documents/Sales_conflict_(0), folder is not empty, can not replace to file
25.08.21 16:54:31 [QNFsDictionary-setObject] QNFileInfo path: /NAS Documents/PSO_conflict_(0), folder is not empty, can not replace to file
25.08.21 16:54:38 [QNFsDictionary-setObject] QNFileInfo path: /NAS Downloads/From Green USB/Intel_VGA_25.20.100.6471_RS5_20181228/Lang/fi-FI_conflict_(0), folder is not empty, can not replace to file
dolbyman
Post by dolbyman »
I have never used Qsync .. but it could be a permission issue.
Does the user/workstation in question have the same permissions ?
surferkhaled
I'm not sure I follow you - same permissions as what?
The user has an account on the NAS and this has been working fine until I think when QNAP introduced a new feature a few weeks ago, now to think about it, the model is TVS-871T and since purchasing a few years ago, I have been using qsync without this issue, this is a recent issue so something changed, however, I am unable to pinpoint it.
with spelling and grammatical errors in the long, it's not clear what "can not replace to file" means??
Thanks for your replies in any case.
dolbyman
Post by dolbyman »
Oh I thought you said there were other computers that had no problems with Qsync.
Unless anyone else has any ideas (I have no Mac and as said never used Qsync), a ticket with QNAP should be opened
surferkhaled
Oh, yes, sorry, I misunderstood - there is another machine, a windows machine which I'm currently using as a test box to monitor if the same thing happens, however, so far I have not seen this behaviour.
I'll get a ticket open - I've never opened a ticket before, is it via an email address that you could kindly share?
Thanks.
dolbyman
Post by dolbyman »
done via the builtin helpdesk app or via the service portal
https://www.qnap.com/en/support-ticket/
surferkhaled
Ok thanks!
Ticket submitted, shall update when I know more.
jeadhob
Post by jeadhob »
I would love to know more about this. I am having the same issues. Spent an hour "renaming or removing" the conflicted files only to have them all come right back 3 days later. Sync was on the entire time. This may sound odd, but I feel that every single file that was changed, I had edited or modified at one point over the last year. Those are getting flagged conflicts, but files that other people at my company have used are not.
RedStapler
Post by RedStapler »
Hello, I have exactly the same problem...
I have two laptops.. Macbook Pro 13 and 15
My QSync folder is renaming folders somehow because both computers sync to the QSync folder.
However... I have not been able to find out why.
It is making a HUGE MESS of my folder structure
If anyone figured this out I'd be real happy.
Also.. it did not always do this.
It started with an updated the QSync agent a few months ago.
PieterHermens
First post
Post by PieterHermens »
I have the same problem. Exactly RedStapler. It startet round 1 septembre. Therefore no problems.
jeadhob
Post by jeadhob »
Two weeks ago I decided to just go file by file and rename them all "without a conflict" and monitored which ones had modifed or changed dates to make sure I had the most recent file.
I spent hours correcting the 2-3 shares I had along with all the sub folders. Everything was working perfectly fine for about 10 days until about 1 hour ago... within an hour I have hundreds of duplicated "conflict" files. This is making Qsync unusable at this point.
I am on a Mac Running the most recent software (no beta) I am running Qsync 5.0.1.0802 Please advise on what we can do to resolve this. If we cannot get this situation sorted out we are going to have to find a different sync solution between our PC's and Macs.
robdou
Post by robdou »
I ve the same problem. Until 21.Oct2021 Qsync was working fine with 2 laptop syncing a share folder.
Laptop1 with windows10
Laptop2 with MacOS High Sierra 10.13.6
on the mac, I see now new folders which seems copy of the original folder but renamed with "_conflict_(0)" sometimes even triple folder
as example:
foldername
foldername_conflict_(0)
foldername_conflict_(0)_conflict_(0)
the files seems randomly split between these folders makeing it a nightmare to concatenate
any help will be appreciate
Robert
pcroozen
Post by pcroozen »
surferkhaled wrote: Thu Aug 26, 2021 4:27 pm Ok thanks!
Hi surferkhaled did you get an answer?
I've also created a ticket myself.
As this has been happening at random dates (random to me). The first time I'd noticed this was August 22nd 2021 and now a few times in October. But in October I lost the original directories and only was left with the _conflict_(0)_ variants and no files on my Mac. They are on the QNAP but I'm losing my faith in this backup solution this way. Besides it's a hassle getting them back.
4.5.4.1800 build 20210923 (It started when I was running 4.5.4.1741 build 20210726)
macOS Catalina
Qsync: 5.0.1.0802
Any help appreciated,
Patrick
Return to “File Sharing”
