Could somebody recommend IP camera that's compatible with QNAP (TS-231, SS ver 5.1.1.3.2)? I would need 5 cameras (3 indoor and 2 outdoor). The features I would like to have are:
* good night vision
* motion detection
* wireless (wifi)
* weatherproof (outdoor cameras), white color (indoor)
* easy setup and trouble free operation (don't want to climb the side of the house every week to reset it)
What I am looking for is an input from actual users. So if you have camera that's working fine for you, was easy to setup, please post make and model. My budget is up to $100 per camera though I can spend more if I can achieve "set it and forget it" with the camera.
Need recommendation for compatible camera for my QNAP - TS-231
Re: Need recommendation for compatible camera for my QNAP - TS-231
I started with cheap Onvif compatible IP cameras, but I have changed them in all HIKVision cameras.
Using DS-2CD6412FWD-C1, DS-2CD2142FWD-IWS, DS-2CD2132F-IWS and very satisfied.
Regards,
Leshen
Regards,
Leshen
