Hi All,
i'm having no end of trouble with the live view and playback areas of the Surveillance Station.
I cannot get the web live view or playback functions working, they just say to install the addon / add to Intranet sites lists.
I have done this and nothing works. I then read that there is no support for 64bit browsers.
So i turned my attention to the QVR Client software.
I installed the latest version I could find (QMon_5.1.0_20160129) but it opens up with this "RGError" popup, i can click ok but then there is nothing I can do. (i have "v build 20170322" in the left menu) but no actions to perform.
If i Use the older version of QMON (QMon_20150630) i don't get the error but I only get a blank page.
Tried it on 2 different Domain Joined Computer and 1 workgroup (all win 10 64bit)
QNAP TS-451U (Version 4.3.3.0188 16/05/2017)
Surveillance Station 5.1.1.4.2 (2017/03/22)
Windows 10 64bit.
The live view and playback functions work on the Mobile App (Vmobile)
I have also tried the QVR software on a Mac and it works fine.
everything is just over the Local LAN.
QVRClient RGError
Re: QVRClient RGError
I have the same problems. It seems to be the update from QNAP Surv. Station or WIN 10 Pro 64bit Update ...
i tried many features, but no chance. Now use mac-client from QVR and the mobile version Vmobile (that works).
anyone ideas?
anyone ideas?
Any progress on this?
Having the exact same issue..
Not sure if this is any help and im not even sure its what fixed my problem becuase i had a similar problem.
I the QVR pro app you'll need to create a monitor type or view type (cant remember what it is called )where you define how many cameras you want to view.
Regards
Regards
Just installed QVR Pro. Looking good so far.
As a "newbie" to QNAP and QNAP apps I really appreciate all tip I can get.
Thank you!
Thank you!
