Hello, I would know if it's possible to enable motion detection manually from Vmobile app and from Surveillance Station.
Thank you.
Motion Detection on demand
Re: Motion Detection on demand
how is manual motion detection supposed to work?
or what do you mean?
I mean that my ip camera always turned on and I would enable motion detection only when I go out from my house.
From ip camera web administration page I can enable/disable motion detection and the same I can do from mobile app, so I would know if Vmobile app provide the same opportunity.
Thank you.
Thank you.
you could unclick the option "enable alarm recordings" or "start recording when motion is detected" .. both are available on the web frontend ..not sure about the app
you could use a schedule to control when to capture/handle motion detection
Hi, this is a question i'm also intersted in. A schedule is good, for example my cameras is enabled for motion detection between 11 p.m to 6 a.am every day, but when I am away I want to easily update that to 24/7. The best opportunity would be if there is an app-function where you can activate motion detection.
