I am having trouble connecting to my tp-link NC450 through surveillance station.
I have updated surveillance station on my TS-451 and the firmware on my NC450.
I have the compression settings set the same, checked the username and password and checked the ip address and ports.
Here is a photo of the settings:
I can connect to the camera just fine through the browser using 10.0.0.25 and the login information I am using on the surveillance station page.
Any idea what I am doing wrong?
getting error "connection failed. the ip address is invalid" with ts-451 and tp-link nc450
Re: getting error "connection failed. the ip address is invalid" with ts-451 and tp-link nc450
same camera, same NAS, same problem...did you find a solution?
- Trexx
Is the camera on QNAP's compatibility list? Have you opened a helpdesk ticket with QNAP?
Paul
UPS: CP AVR1350
UPS: CP AVR1350
- sentinelvdx
Sam here, but with TS-251+
NAS: TS-251+ 16GB DDR3L 1600mhz CAS11
Firm: QTS 5.0.0.xxxx
HDD's: 2x 4TB HGST Deskstar NAS - RAID0
Port Trunk: 802.3ad w/ Systimax CAT6a
Hi Guys,
Saw this and sadly I have to bump it. I have TS251+ and TP-Link NC450 and while configuring I can see the preview but sadly once I am out of it I see
Status: Connecting
Recording Status : Not Recording
Did anyone managed to check this?
D-LInk works rightaway on similar settings.
Status: Connecting
- storageman
It is approved.
Are u running 5.1.1.3(4).3.20170428 SS and camera has 1.2.3 Build 170316 Rel.D60AD9 firmware?
