Survellance Station / QVR Pro not connecting D-Link DCS-936L
mr.manic
Post by mr.manic »
i try to connect an D-Link DCS-936L (from the compatibility list) to the SS or QVR pro, buit have the "still connecting"-problem. See attachments.
The cam works fine over WiFi in my browser an i get "TEST OK" and a positive ping result in SS and QVR. But no picture in this applications.
UPNP and forwarding is set (TCP 80, 443, 554) and the ip configuration is correct.
I tried the workaround with 15 FPS and lower resolutions, but nothing works.
I tried the cam as exposed host, nothing changes.
QTS: 4.3.6.0093
QVR pro: 1.2.1.4
SS: 5.1.3.4.5
DCS-936L: 1.08.03
Any ideas?
Thx in advance,
Mr. Manic
QNAP TS-453pro, 8 GB, 4x4TB WD Red
mr.manic
Re: Survellance Station / QVR Pro not connecting D-Link DCS-936L
Post by mr.manic »
Hello everybody,
after contacting the QNAP Support, the workaround was going back to firmware v1.05.07 on the DCS-936L, because all newer ones having issues.
Now it works fine. Thanx to the QNAP Support (was really fast).
Hope that'll help someone else.
Best regards,
Mr. Manic
