Hi all,
Bought a W5 Wansview cam and i don't find parameters to configurate it (i only find people who did it on Synology)
It is detected automatically as a Onvif cam but never connect using 554 rstp port, Onvif port programmed on Wansview Android app
whether with or without a password.
Curiously I don't detect my cam with Onvif cam manager; All equipments(NAS,PC,W5 CAM) are on the same local network.
TEST PING done on NAS:
PING 192.168.1.24 (192.168.1.24): 56 data bytes
64 bytes from 192.168.1.24: seq=0 ttl=64 time=3.918 ms
64 bytes from 192.168.1.24: seq=1 ttl=64 time=3.799 ms
64 bytes from 192.168.1.24: seq=2 ttl=64 time=2.674 ms
--- 192.168.1.24 ping statistics ---
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 2.674/3.463/3.918 ms
someone would have successfully set it up?
Thanks in advance.
[Solved] Wansview W5 configuration
Re: Wansview W5 configuration?
Onvif port 8899 programmed on wansview Android app; Nat tcp and udp 8899 port opened on router
now i can see this cam with Onvif cam manager; Live video give rtsp "rtsp://192.168.1.24:1554/live/ch0?token=00866581ed849b7a439b744b894e50fb"
with vlc i can see the video stream
but no more progress on the Nas... even with "/live /ch0", 8899 port and rtsp 554...
soo Happy, i have found the right configuration!
ONVIF ProfileS Cameras
Port:8899
Port Rtsp: 1554
Adresse Ip réseau etendue WAN: /live /ch0
Port:1554
Port Rtsp wan: 554
no user, no password
the sound is crunchy but i don't care.
Port:8899
Port Rtsp: 1554
Port:1554
Port Rtsp wan: 554
Re: [Solved] Wansview W5 configuration
Hi, can you help me to configure W6 model with latest version of Surveillance Station on my qnap TS-251A with latest firmware.
I don't undestand to connect the ipcam to the nas.
I don't understand if it is obligatory to register on the wansview site or I can configure it without having to register. I don't want to use the Wansview cloud, I want to have everything managed by Surveillance Station.
Is it possible ?!?
Thanks a lot.
Is it possible ?!?
Thanks a lot.
Someone can help me ?!?
Thanks a lot.
Thanks a lot.
Ok it's work.
How did you do? What exact configurazione have you used?
