I recently installed HIKVision and Reolink cameras at home and found them very easy to install and operate with QVR. The HIKVision Hikvision DS-2CD2365G1-I 6MP (PoE) was inexpensive, has excellent night vision, and very good quality images. The Reolink E1 Zoom (WiFi) works well monitoring a room. Images aren't as sharp but pretty good.
Has anyone had any particularly good experiences with other cameras worth mentioning?
What are the best home secuirty cameras?
- spile
- Been there, done that
Re: What are the best home secuirty cameras?
Amcrest have a number of rebranded Duaha models that are ok. I have two and they are reliable.
Just stick with wired.
Maybe worth a visit here - loads of user reviews, experiences, problems solved, camera info etc :Has anyone had any particularly good experiences with other cameras worth mentioning?
https://ipcamtalk.com/forums/ip-cameras.4/
And quite a lot about Reolink ...
- rafale
- Easy as a breeze
I would also second Dahua but am reserved about amcrest. I have a mix of both and the amcrest firmwares not only are missing features but also when wired tend to crash in relation to QNAP's virtual switches. They don't seem to handle QNAP's surveillance station or QVR pro switching network ports and just decide to hang. The Dahua ones don't have this problem and are also cheaper on aliexpress.
Server: TVS-872XT i9 9900 ES, 64GB DDR4 2666MHz, intel X550-T2, Asus RTX3070 Dual OC (On pico PSU), 2x Phison E12 1TB M.2, 4x Micron 5210 7.68TB, 4x WD Purple 4TB
Backup NAS: TS-473 20GB DDR4 2400MHz, Mellanox ConnectX3, 2x Samsung PM871b 256GB M.2, 4x WD Red 8TB
Former units: TVS-1282, TS-871, TS-469
Many Amcrest cameras are rebranded Dahua models these days.
The dumbed-down Amcrest firmware can in some cases be replaced by the equivalent model Dahua firmware, smartening the camera up a lot.
- spile
I share concerns about old Amcrest firmware however...
The cameras are reliable and work just fine
The two I have are listed on QVRPro
The sub £80 price worked for me
I am on the hunt for a new 4k POE PTZ dome camera. So anyone with thoughts would be helpful. Right now I am running two older JideTech 1080 PTZ POE Dome cameras that work surprisingly well for the past 2 years.
NAS: QNAP Turbo NAS TS-870U-RP, 16 GB Ram
CPU Upgrade: Intel i7-2600S
System Fan Mod: AVC DE07015B12L 7CM 12V 0.3A 7015 AVC CPU (x2) Fan to reduce Motherboard fan noise - (easy drop in)
PSU Fan Mod: SUNON HA40201V4-000U-999 4cm Super-silent Fan Magnetic (X2) - (modded each power supply myself, some soldering, but easy mod)
