QVR 2.0.0.0 failed to start
somy1982
Easy as a breeze
Post by somy1982 » Mon Mar 08, 2021 12:03 am
I updated QVR pro to 2.0.0.0 but after that I couldn't get the app started.
Every time when I try to start it hangs for 10 mins and report "failed to start".
Any suggestion what to do? Thanks
rkbuye
Re: QVR 2.0.0.0 failed to start
Post by rkbuye » Mon Mar 08, 2021 12:28 am
I am in the same boat - updated and now failed to start!
spile
Easy as a breeze
Post by spile » Mon Mar 08, 2021 3:49 pm
I would open a call with Qnap
sdmac
Post by sdmac » Tue Mar 09, 2021 2:24 am
I have the same issue. I've tried rebooting & manually starting it - no good.
Ends up with the super unhelpful log entry...
Error	2021-03-08	12:17:57	admin	127.0.0.1	QVR Pro	Installation	[QVR Pro] Container Station is not started.
I would go ahead and uninstall / reinstall QVR Pro but i would have to setup all the (24 of them) cameras AGAIN!
Does anyone know if there is something in the file system (I have SSH access) that i can backup the QVR Pro settings before uninstall?
PS I have opened a ticket - waiting reply - but not holding much hope since all they ever say is "enable remote connection" (I have 6 tickets on the go) and on each one I say "I cannot due to corporate environment" - send logs and screenshots and everything but I am not convinced anyone looks at these?
AlastairStevenson
Experience counts
Post by AlastairStevenson » Tue Mar 09, 2021 4:03 am
Have you checked the status of Container Station?
It's required as part of QVR Pro.
gribnut
Post by gribnut » Tue Mar 09, 2021 8:18 am
Not sure of method to backup/restore at file system level, but there is a feature in the QVR Control panel to backup and restore settings (I've not used to restore).
sdmac
Post by sdmac » Tue Mar 09, 2021 4:14 pm
There is, but as QVR Pro wont start, I cannot access it. :(
sdmac
Post by sdmac » Tue Mar 09, 2021 4:15 pm
Yeah, it starts.
Thing is, you dont actually have to "start" container station (I didnt on 4 other working units) - I guess under the hood, QVR Pro start ups the necessary components.
spile
Easy as a breeze
Post by spile » Tue Mar 09, 2021 6:06 pm
I suspect the recent update to QVRPro is the source of the problem. I am now having problems running it.
somy1982
Easy as a breeze
Post by somy1982 » Tue Mar 09, 2021 6:16 pm
Support gave me a new version of container station, but it doesn’t solve the problem.
sdmac
Post by sdmac » Tue Mar 09, 2021 10:35 pm
Hi all, just to let you know. Support sent me a link to Container Station app v2.3.5.1708 to perform a manual update.
* installed Container Station app v2.3.5.1708
* rebooted
* found QVR Pro in App center & clicked the gray "Start" button
It is working once more.
somy1982
Easy as a breeze
Post by somy1982 » Tue Mar 09, 2021 10:37 pm
* rebooted
They sent me the same version but it didn't solve the issue. They're looking into it again.
xaviler
Post by xaviler » Fri Apr 16, 2021 8:51 pm
hi there,
got the same error / fault here ... did you find a solution yet ?
