Qusbcam2 v 1.1.1
dremn
Qusbcam2 v 1.1.1
Post by dremn » Tue Mar 09, 2021 9:25 pm
after upgrade to v 1.1.1 camera connected to USB is timeouting. Then disappear from Qusbcam2.... How I can downgrade to previous version.. or who can fix this issue. Thank you
Using TS-453d
dremn
Re: Qusbcam2 v 1.1.1
Post by dremn » Sun Mar 14, 2021 4:42 pm
Ok so problem is solved, in surveillance station your usb cam must be added under ADMIN, otherwise its not working properly.
