Hi
I have a TS-251D and would like to add a battery powered, wifi outdoor camera however having gone through many web sites, I cannot find any that are compatible? Can anyone help or shed some light on this for me?
Wifi Battery Powered Outdoor Camera
Re: Wifi Battery Powered Outdoor Camera
Build your own powersource then
car battery and dc-dc converter for instance
this way you could use any wifi camera your like
Not really an option dolbyman, I would have hoped for a much simpler solution
I have been struggling to find anything useful, and most of the threads I found were 2018, 2019.
Now, in 2022, is there any brand like Eufy, Arlo, Ring etc which I could get and use QNAP as a storage?
It is imperativ the cameas to use Wifi and are bateery powered.
Thanks and cheers!!!
