Problem with starting the Surveillance Station service after upgrade QTS
andrevtix
Post by andrevtix » Wed Apr 14, 2021 9:25 pm
Ha
I have a problem with the Surveillance Station service. With the software 4.4.3.1439 everything worked as it should, but since the update to 4.5.xxx I still have the same problem, i.e. the Surveillance Station service cannot start. Do you have any idea how to deal with this problem ?
dolbyman
Re: Problem with starting the Surveillance Station service after upgrade QTS
Post by dolbyman » Wed Apr 14, 2021 9:27 pm
tried to uninstall and reinstall surveillance station?
otherwise a good idea to open a ticket with qnap
andrevtix
Post by andrevtix » Thu Apr 15, 2021 2:42 pm
I cannot uninstall the service because there is still information "starting", it cannot be turned off and the application itself does not start. If no one has an idea, I have to make a service request to QNAP ...
