2DE2A404IW-DE3 not accepted - no PTZ control possible in QVR cllent..
wha17
Post by wha17 »
i have a
HK-Vision DS-2DE2A404IW-DE3, in the drop-down i see only DS-2DE2A404IW which is not accepted. (error when testing).
After 1 min, the camera starts to appear even with the failed test... but PTZ does NOT work with the QVR client (i am using 2.2.170221) on a mac... and on windows (5.1.5.21117).
Qnap: TVS-EC-1080 Firmware 4.5.3.1652
Surveillance Station: 5.1.5.4.4
So any idea?
Without PTZ the solution is useless...
If i connect to the camera directly i can control the camera...
Port is 80
RTSP-Port is 554
Any idea?
