QVR Pro Storage Location
I have a storage volume (SurvVol1) configured for QVR Pro, but when I open the Recording Explorer I see that the recordings folder (QVRProRecording) is in on different volume (SysVol1). How do I get it to store the recording files in the correct place? I doesn't look like these are symlinks or something like that.
- spile
- Been there, done that
Re: QVR Pro Storage Location
I think this is set by the application. I believe the only option is to copy files from the Standard recordings folder to a different location as a backup for example. A call to Qnap would confirm this or otherwise.
