This is happening on 3 different QNAPs I have. Even though I have set the Overwrite Trigger Threshold to 95%, it continues to record till it reaches 100% and then stops recording.
Alternatively I have tried setting the Recording Location and Days to At Least 90 and Up To 123, but it still does not overwrite the oldest video.
What do I need to do so that it continuously records without running out of storage space?
TS-873U-RP Firmware 4.5.4.1723
QVR Pro 2.1
QNAP doesn't overwrite old videos. Out of storage!
Re: QNAP doesn't overwrite old videos. Out of storage!
im had same issue with my qnap device but im backing up with my device.
my old data does not owerwrite and not update, so my device full up and dont backup.
i try to backup with two software (Veeam-Veritas) and get same eror: Owerwrite issue
