TS-253D - QVR PRO problems sin F/W update
wytco0
Post by wytco0 »
I recently updated my firmware to 4.5.4.1723 and since then I have been unable to get QVR PRO to run. I have now removed it and Container station several times.
When I try and install QVR PRO it says downloading but then often silently fails to install, sometimes it does install but when I try and run it its fails I can see a message in the logs saying :
install version: Container Station 2.3.5.1708
Warning: Container Station is not working properly. Re-install Container Station and try again.
However, Container Station is installed and has been many times, normally it had been installed as a dependency when the QVR Pro install starts but even when I install it manually I am getting the same message.
Any ideas what else I can try? I have been trying to sort this out for several days now
dolbyman
Re: TS-253D - QVR PRO problems sin F/W update
Post by dolbyman »
Best to open a ticket with QNAP, if there is a bug, they need to fix it
