QVRPro TS251+ memory leak
buzzbusy
Post by buzzbusy »
Hello
We use QVRPro with 3 camera recording on a TS251+ nas with 6GB of RAM.
We also has QVRPro Client always on (live monitoring)
Everything works fine, but we experience some memory problem :
- when we launch QVRPro it take around 1GB of RAM
- then the RAM usage in increasing slowly until the RAM is over (QVRPro is more than 3GB after few days)
- the only solution is to restart QVRPro, it reset RAM usage and it work normally for few days again - usually around 5 to 6 days.
Does anyone have the same problem and could you please tell us how to fix it ?
(we have the event trigger on one camera)
Thank you by advance for your reply
Best regards
lbjoernk
Re: QVRPro TS251+ memory leak
Post by lbjoernk »
It sounds like a bug. Are you using the latest version of both the TS firmware and QVRPro? If not, then start by upgrading.
If still an issue, raise a QNAP support ticket.
buzzbusy
Post by buzzbusy »
Hello
Thank you for your answer, everything is up to date
So I will open a ticket
lbjoernk
Post by lbjoernk »
Did you get a reply from support? Something they could reproduce and maybe fix?
