I switched to using QVR Pro on my TS-453A (16 Gb, 4x4Tb, 4 cams). It took some tweaking, I'm not done yet, but most of it is stable and working.
What I want to do is keep an off-site copy of my surveillance data in OneDrive. I'm using HBS3 to set up a one-way, real-time sync (mirror) to my OneDrive space. I've chosen the \Standard_Format folder as SOURCE.
The result I see is quite unexpected; it does synchronize, but only to the situation at job start; it synchonizes the dates and hourly directories until the moment I started the sync job. Any future files and directories added to the SOURCE folder seem to be ignored by the HBS3 job.
Fun fact: when I manually copy a test directory containing some files into the SOURCE folder it gets synced to OneDrive straight away.
I haven't been able to replicate this behaviour with test directories, using each combination of active/one-way/two-way sync and move/copy/mirror options.
Anyone who can help? I've seen other messages on this forum on the combination of HBS3 and real-time cloud synchronizing issues but not about this specific behaviour.
Kind regards,
Ignasz
QVR Pro backup to OneDrive using HBS3
- spile
- Been there, done that
Re: QVR Pro backup to OneDrive using HBS3
Have you opened a call? What was the response?
Yes, I have.
Unfortunately, the response was : "Unfortunately, QVR Pro doesn't support real time backup due to technical concerns."
As you see, hardly informative.
They suggested to change into a periodic backup. For security reasons however, you'd have to rely on near realtime synchronizing to keep off site copies when a NAS is destroyed or removed.
Anyone has a better idea?
Kind regards,
Ignasz
Kind regards,
Ignasz
- spile
I backup my events to an external usb Drive.
Hi
Did you ever solve this? am too trying to get this to work, have tried one drive, google drive and now ftp. ftp works the best but still need to do periodic backups which is annoying. thanks
Did you try scheduling instead of a live backup? Syncing video files that may be open and locked will be problematic unless the app is designed specifically for that (which I would doubt).
