I'm looking for cameras that support PoE (Power Over Ethernet). Anyone have any experience with PoE cameras?
Br
Kenneth
- Valnurat
- Easy as a breeze
Re: Anyone have any experience with PoE cameras?
I will be interested to see the replies, I was just searching for PoE cameras as well.
I do have experience with PoE in general (mostly wireless access points). I would be interested in something that can use the 802.af specification, and/or the cisco standard (I happen to have a Cisco 3560 PoE switch laying around). Alternatively anything with an injector would work, I just want to play with power budgets
well I found one so far: http://www.smallnetbuilder.com/content/view/30314/80/
I am sure others will find more.
- Valnurat
- Easy as a breeze
Yes, I have seen it too, but I was hoping to find camera like this.archivalbackup wrote:well I found one so far: http://www.smallnetbuilder.com/content/view/30314/80/
http://www.axis.com/products/cam_q6032e/index.htm
I have recently purchased a very good POE camera - The Panasonic BL-C160
This is a really great POE type of web cam that is ideal for external use - and available at a very reasonable cost as well - £226 from Amazon
Simon
Simon
QNAP TS-239 (v 3.8.2). Seagate Barracuda ES 1000GB x 2. SSOTS 4.14 SBS 7.7.2-33893
QNAP TS-109 Pro (v 3.3.2 build 0918T). Seagate Barracuda ES 750GB.
2 x wireless SB3, 1 x wireless SB2, & 1 x SB Controller. Controlled via iPeng (the best app for the iPad/iPhone) with SBS Spotify app
& an old Qnap TS-101 (v 2.5.0 build 1210T) for secondary backup.
Panasonic BL-C210 & BL-C160 Wireless Cameras
- Valnurat
- Easy as a breeze
But the Panasonic BL-C160 isen't on the Compatibility List.
Does it work anyway?
Try the BC-C1, works ok with meValnurat wrote:But the Panasonic BL-C160 isen't on the Compatibility List.
