Today I bought a Qnap TS-119 specifically because it's suppose to support the D-link DCS-2120 I had already.
I tried a lot of things but can't get the Qnap to record on motion detection...
Do you have any solution for this please?
Thanks,
Steve
D-link DCS-2120 not working on Qnap TS-119
- schumaku
Re: D-link DCS-2120 not working on Qnap TS-119
Common causes:
1. Motion detection (area, sensitivity, ...) must be configured on the camera.
2. Sometimes, a privileged access to the camera is required, so the Surveillance Station can control some features.
-Kurt.
-Kurt.
I configured Motion detection as explained on below link but it still does not work...
http://www.dlink.be/cs/Satellite?c=Tech ... FDLWrapper
It seems that I don't have the button "enable recording on this camera" (in settings - camera settings).
Also I'm getting this error
Any ideas?
Any ideas?
- petur
- Moderator
Praat je liever over QNAP in het Nederlands?
Liever een community bij jou in de buurt?
Kom naar QNAPclub België/Nederland
Hi Peter, I did see this... If I apply these parameters I'm getting an error message "unknown error -5"
This seems like a bug in the Surveillance station software.
Can this be solved?
Can this be solved?
I've been playing a bit more with it and it I put /cgi-bin/video.jpg?cam=3 ?quality=5 ?size=5 it seems te record something!
However, I'm not able to modify things like resolution, frame and quality.
Also it it recording continuously, it would be better if it only record on the detection of motion.
Does somebody has any idea where to fidn the cdf of a dlink DCS-2120?
Thanks,
Steve
Thanks,
Steve
Nobody encountered this problem???
- petur
- Moderator
if the community here can't help, contact QNAP online support....
I did that already but they are not getting back to me...
I am having same issue unknown -5 error
