Visual SVN with QNAP TS-870
Hello everybody... My name is Wojtek and I am working as a Junior System Administrator in a small fast growing company I will have one question to you guys. We are planning to run SVN server but we are aiming for Visual SVN software. It will have its own dedicated server and my question is it possible to run SVN repository using data from the QNAP?
Re: Visual SVN with QNAP TS-870
Hey Wojtek, I found a solution that works perfectly with your NAS, SCM Manager, it is a Java application that runs directly in you NAS, https://www.scm-manager.org/
Hi eivarrocas, I found the QPKG file for SCM Manager in this forum, but it is a bit old and I need a recent bug fix. Can you help me figuring out how to install the new SCM Manager on the NAS?
Thanks!
Thanks!
