Hi, very "simple question".
I try to map the shares from my Windows 10 after not using my TS-109 for many years. I have installed QNAP finder pro
but the only meny I can use there is
Configuration and Details...
Wrong version of the SW?
Any tip how to use my NAS-server with Windows 10 - I know it is not supported but maybe there is a way
Rgds
PS: It is cable wired to the Netgear Nighthawk X4S AC2600 and the PC is cabled to the router...
PPS: Can I cable- connect and see the files easily?
PPS: I just recalled there is a web-login and tried:
http://192.168.0.109:8080/index.html
no connection/lookup... (I see the NAS-server in Qnap finder though)
Getting mapped drives from my Windows 10 for my TS-109 :-) (back on it after +5 years)
Re: Getting mapped drives from my Windows 10 for my TS-109 :-) (back on it after +5 years)
why shouldn't your not be supported in win10 ?
try pulling the drive and see if the setup comes up
