Losing Space - Network Recycling Bin Disabled
QNAP: TS569 Pro
Firmware Version: 4.3.3.0262 Build 20170727
QSnyc Enabled
Windows 10 64-bit
I am consistently losing space on my QNAP and I have no idea why. I have my QNAP set up with five (5) 3TB drives in a JBOD format with a total capacity of 13.23TB, According to Storage Manager, I've used 5.54TB. However, that is next to impossible as I nothing but a 8.04GB file in one folder and nothing in the other two folders. I have Show Hidden Files and Folders enabled. I do have QSnyc enabled but the lone folder I have synced on my local computer is only 54.2GB.
I do not want to simply reformat the QNAP as that will not answer the actual problem. There is over 5.5TB of data on my QNAP that I cannot find. The strangest part is that every time I delete something from the QNAP, the available disk space decreases. Again, the network recycling bin is disabled.
QSnyc Enabled
Windows 10 64-bit
- Trexx
Re: Losing Space - Network Recycling Bin Disabled
SSH into your NAS and run the following:
df -h
Paul
UPS: CP AVR1350
UPS: CP AVR1350
Thanks. Here is the screen shot
- Trexx
Hmm have you tried running check file systems?
Paul
UPS: CP AVR1350
UPS: CP AVR1350
Not as of yet. Do you mean run check disk on QNAP within Windows? Do it matter that it's a network drive? ...or is there a way to do that through Terminal/SSH?
on the qnap..not windows
- Trexx
See the documentation for how to perform it:
http://docs.qnap.com/nas/4.3/cat2/en/vo ... filesystem
Paul
UPS: CP AVR1350
UPS: CP AVR1350
- schumaku
Check this...
This will create an output like this - a good start for where to investigate:
[~] # du -s /share/CACHEDEV1_DATA/*
12 /share/CACHEDEV1_DATA/AAAtest
8 /share/CACHEDEV1_DATA/aquota.user
7912 /share/CACHEDEV1_DATA/Download
100 /share/CACHEDEV1_DATA/homes
16 /share/CACHEDEV1_DATA/lost+found
165309636 /share/CACHEDEV1_DATA/Multimedia
53884944 /share/CACHEDEV1_DATA/Public
12 /share/CACHEDEV1_DATA/Recordings
16 /share/CACHEDEV1_DATA/Web
Thanks. Here is what I got after it completed...
[attachment=0]Screen Shot 2017-08-02 at 7.16.32 PM.png[/attachment]
From what I can tell, both the 57615896KB/57.6GB folder and the 8597212/8.59GB folder are accurate. The former is QSync and the latter is What is currently on the QNAP. That still leaves well over 5TB unaccounted. I'm not one to throw this word around but is there any way this could be a viral issue? I enabled the QNAP antivirus. Would this be better than the local computer-level antivirus protection I use?
antivirus only scans the files ... ir does not pritect the nas from malware
I figured that was a long shot. Any other thoughts as to what this may be?
- Trexx
Have you run the check file system yet?
Paul
UPS: CP AVR1350
UPS: CP AVR1350
Trexx, is that "Control Panel -> Storage Manager -> Disks -> Action -> Scan Now" for each drive?
- Trexx
http://docs.qnap.com/nas/4.3/cat2/en/vo ... filesystemts569prohelp wrote:Trexx, is that "Control Panel -> Storage Manager -> Disks -> Action -> Scan Now" for each drive?
Paul
UPS: CP AVR1350
UPS: CP AVR1350
I don't think I need to check my file system at this time. I do not have any error messages indicating my file system is not clean. Additionally, this is what I see when I go to Storage Manager -> Storage Space
[attachment=0]qnap1.PNG[/attachment]
