I've bought a new TS-431P, installed it with the latest QTS 4.3.3.0277, configured it, and also configured the shared folders. At that time, I was able to access all the shares without any problem from my Windows7 Pro x64 notebook, and from another Win7 notebook as well. Then the NAS informed me that it is swapping too much, so I restarted it (by pressing the On/Off button). Since then I cannot access the shares. I can access the NAS (and configure it) via the QTS GUI from web-browser, via Qfinder, I can see it in Windows Explorer among "Media Devices". But cannot access the shares from Windows Explorer or other Windows program. And also, I now cannot connect to the NAS from Android, not even from the Qmanager app (before restart it was possible), but this might be a different problem.
When I try in Windows Explorer e.g. \\192.168.xx.xx\Multimedia, I'm getting
Windows cannot access \\192.168.xx.xx\Multimedia, Error code 0x80004005 (Unspecified error)
Windows cannot access \\192.168.xx.xx, Error code 0x80070035 (The network path was not found)
It seems to me as if the smbd is not running, in "ResourceMonitor > Processes" I cannot see this process.
Finally, I logged in via putty, and "ps -efH|grep smb" found nothing either.
Then I tried samba testparm utility to check that smb.conf is correct:
[~] # testparm
Load smb config files from /etc/config/smb.conf
rlimit_max: increasing rlimit_max (1024) to minimum Windows limit (16384)
WARNING: The "null passwords" option is deprecated
Processing section "[Multimedia]"
Processing section "[Download]"
Processing section "[Web]"
Processing section "[Public]"
Processing section "[printers]"
Processing section "[homes]"
Processing section "[Documents]"
Processing section "[Software]"
Processing section "[Root]"
Processing section "[home]"
Loaded services file OK.
ERROR: cache directory /share/CACHEDEV1_DATA/.samba/cache does not exist
Server role: ROLE_STANDALONE
What else can I do to make smb run again?
