Windows File Sharing TS-219P+ (error 0x80004005) - Solved by enabling SMB3 using putty
Windows Access Rights Management
Locked
twincam1449
Post by twincam1449 »
I have two QNAP NAS:
TS-219P+ and TS-459PRO+
Both have latest firmware
TS-219P+ 4.3.3.1161
TS-459PRO+ 4.2.6 (2020109)
I can access both NAS through the \\x.x.x.x.:8080 menu
But only the TS-459PRO+ is visable as network drive in Windows Explorer.
I tried with Windows 7 and Windows 10
I have read many posts, but can't find the solution.
Someone with the correct answer to solve the problem?
dolbyman
Re: Windows File Sharing TS-219P+ (error 0x80004005)
Post by dolbyman »
a network drive in internet explorer ? .. you mean file (windows) explorer..right ?
why don't you just mount the shares ? what happens if you try ?
twincam1449
Thanks, you are right. I removed ' internet'
I tried adding a network location
Error: The folder uou entered does not appear to be valid. Please choose another.
dolbyman wrote: Sat Feb 22, 2020 12:26 am a network drive in internet explorer ? .. you mean file (windows) explorer..right ?
dolbyman
Post by dolbyman »
so when you type into windows explorer
\\NASIP
do you get a share listing of the NAS? (whatever IP you entered)
p.s.
just making sure .. the IP you entered up there was a private range (no need to censor this) and not a public one .. right ?
twincam1449
In Windows Explores:
No, listing after entering \\192.168.2.9
It just comes up with windows cannot access \\192.168.2.9
When I enter 192.168.2.9:8080 in Google Chrome it goes directly to the logon screen.
Windows 10:
If I click ' This PC' in Windows Explorer it shows both NAS.
The 459 NAS has a 2D color screen next to it. If I click the 459, it only shows the music, photo and video directories
The 259 NAS has a 3D color screen with QNAP under it. If I click it, it also only shows the music, photo and video directories
If I click Network:
It shows the 459 NAS under " Computer" with the NAS name AND it show the 459 NAs under " Storage"
The 259 is not shown at all
dolbyman
Post by dolbyman »
whatever shows up in your file explorer is probably the NAS DLNA server .. both must have one active
something switched off your SMB server ... can you check if SMB Services are active and the services are bound to the correct interface? (if Service binding is used)
twincam1449
C:\Users\info>sc.exe qc lanmanworkstation
[SC] QueryServiceConfig SUCCESS
SERVICE_NAME: lanmanworkstation
TYPE : 20 WIN32_SHARE_PROCESS
START_TYPE : 2 AUTO_START
ERROR_CONTROL : 1 NORMAL
BINARY_PATH_NAME : C:\WINDOWS\System32\svchost.exe -k NetworkService -p
LOAD_ORDER_GROUP : NetworkProvider
TAG : 0
DISPLAY_NAME : Workstation
DEPENDENCIES : Bowser
: MRxSmb20
: NSI
SERVICE_START_NAME : NT AUTHORITY\NetworkService
twincam1449
Can you help me how to?
In Windows Features ON/OFF I enabled the three SMB1 rules
dolbyman wrote: Sat Feb 22, 2020 1:59 am whatever shows up in your file explorer is probably the NAS DLNA server .. both must have one active
dolbyman
Post by dolbyman »
not sure what you are posting here .. the SMB server is on your NAS .. not your windows system
twincam1449
Is this the info you need? :
NAS 259p+ - controlpanel - system - system status:
Microsoft Networking:
Enabled
Server type: standalone server
Workgroup
WINS server is not running
local master browser is enabled
dolbyman
Post by dolbyman »
twincam1449
It was an easy fix.
Justy enable SMB3.
https://www.markuszehnle.com/2017/10/20 ... s-659-pro/
OneCD
Re: Windows File Sharing TS-219P+ (error 0x80004005) - Solved by enabling SMB3 using putty
Post by OneCD »
Locked
Return to “Windows”
