Hi, i have problem on qnap tvs-ec880 firm version 4.4.2.1270 (2020/04/10), for file format .txt (notepad), can not be created, or pasted in one of the share folders.
I do not set filters for files that will be put in the sharing folder. Initially This problem is found when pasting files with the .txt extension (notepad) to a sharing folder.
a notification appears:
"Item not found" - This is no longer located in \\xxx.xxx.xxx.xxx\folder\folder\folder. Verify the item's location and try again.
in another sharing folder with a different volume, this problem does not occur.
any advice?
thanks,
Help.problem .txt file in folder sharing
Re: Help.problem .txt file in folder sharing
yeey my problem solve,. this answer is veto command in cli on qnap, /etc/smb.config
thanks all
thanks all
