TS212
QTS 4.33.1624
File Station 5.02 (20210416)
Hybrid Backup Sync version 2.1 190909
I cannot view any of my Windows 10 PC drives or folders in File Station or HBS. So I cannot sync or backup any folders from my PC to my NAS.
Please help !
TS 212 Does not display my Windows PC Drives
- OneCD
Re: TS 212 Does not display my Windows PC Drives
Hi and welcome to the forum.
I seem to recall there's a checkbox in the File Station settings that must be checked to show your local PC drives. Have you enabled this?
You are correct. Thanks. However this tick box option is greyed out on mine. See photo
- OneCD
