Hello
I have TS421 4.3.3.1624 and about 500GB of free space, I have the NAS mapped to my Windows 10 PC and have been copying files to folders on the NAS for a couple of years now without issue
For some reason now I try to copy the file and comes back with a network error but I can still access the folders and copy files from different folders on the NAS
I havent changed permissions or anything else as far as I am aware except I think I did a firmware update on the NAS a few days ago
Has anyone else experienced this and found a solution?
Nobber
Cant copy Files to NAS Was working now isnt
Re: Cant copy Files to NAS Was working now isnt SOLVED
Ok so I found the problem, my BT disc decided to connect to my NAS at 2.4 ghz instead of 5ghz so I reconnected it and it went back to5ghz everything ok now
Wasted hours on this, downgraded firmware reset windows network installed new drivers etc etc
I hope this helps someone
