SAMBA login
Windows Access Rights Management
NetWorker
SAMBA login
Post by NetWorker »
Hi, i've recently a fastidious problem, my device ban every minute a local IP just only one pc... in the notification event there is: "user" (not the real of nas) login fail (SAMBA). I've tried an read all possible solution of other user that have the same issue but it's still remain... The OS is Windows 10 Pro build 21H1 and hasn't problem i'm an IT worker... Someone has ideas or suggestion? Thanks to all
dolbyman
Re: SAMBA login
Post by dolbyman »
the wrong credentials will be set in a machine, either in a program or in the credential storage
NetWorker
Re: SAMBA login
Post by NetWorker »
no absolutely, was the first thing tried.... deleting, mapping unit, user group, guest access software driver and so on, but nothing credential are ok and the issue came out recently (abount 4-5 months)
Return to “Windows”
