Only access from specific ip address
Windows Access Rights Management
daxliniere
Post by daxliniere »
Hey gang,
Having a bit of an issue and can't seem to solve it on my own. I set up a PC #2, it is almost identical to PC #1 in hardware. The Windows 10 installation is a direct image from PC #1 (Macrium Reflect FTW).
PC #2 has it's own IP address, as assigned in gateway DHCP server by MAC address.
PC #1 can access my QNAP TS-231K NAS (v4.5.4.1741) via web browser, Windows Explorer and ping. PC #2 cannot do any of those things. (Ping: Destination Host Unreachable, Web: This site can't be reached)
I thought I might have only allowed access to PC #1's IP using QuFirewall, but even when I uninstalled QuFirewall, I can't access the NAS. IP Access Protection shows 0 rules, when I uninstalled QuFirewall, it showed 'allow all'.
I have a Unifi USG gateway, but there are no firewall rules which would cause this. I have also tried disabling Windows Firewall, but still no joy.
Can someone suggest a solution or some tests I can run, please? PC #2 is otherwise working perfectly well. I can access the modem, switch and gateway (ping/web browser), so it seems to be restricted to accessing the NAS.
All the best,
Dax.
daxliniere
Re: Only access from specific ip address
I can confirm that I also can't access from my phone on the wifi network, but I can access from my laptop which is on the same wifi network as my phone.
Seems like there are access rules that I can't adjust in the NAS??
llleite
Post by llleite »
did you fix the issue? I had the same issue here, one of my pad can access through LAN, but my phone can not. very wired.
Return to “Windows”
