TS-251.
QTS 4.2.2
Container Station 1.6.1701
Don't work dind (docker in docker). Needs for Drone ci, Gitlab ci, etc...
Docker service don't start in container.
docker run --privileged -it --name some-docker docker
INFO[0000] libcontainerd: new containerd process, pid: 14
ERRO[0001] devmapper: Udev sync is not supported. This will lead to data loss and unexpected behavior. Install a dynamic binary to use devicemapper or select a different storage driver. For more information, see https://docs.docker.com/engine/referenc ... ver-option
ERRO[0001] 'overlay' not found as a supported filesystem on this host. Please ensure kernel is new enough and has overlay support loaded.
INFO[0001] Graph migration to content-addressability took 0.00 seconds
WARN[0001] Your kernel does not support kernel memory limit.
WARN[0001] mountpoint for pids not found
INFO[0001] Loading containers: start.
WARN[0001] Running modprobe bridge br_netfilter failed with message: modprobe: can't change directory to '/lib/modules': No such file or directory
, error: exit status 1
WARN[0001] Running modprobe nf_nat failed with message: `modprobe: can't change directory to '/lib/modules': No such file or directory`, error: exit status 1
WARN[0001] Running modprobe xt_conntrack failed with message: `modprobe: can't change directory to '/lib/modules': No such file or directory`, error: exit status 1
FATA[0001] Error starting daemon: Error initializing network controller: error obtaining controller instance: failed to create NAT chain: Iptables not found
