I get the following error when attempting to create a
jupyter/datascience-notebook container
Background task error for create: failed to register layer: ApplyLayer exit status 1 stdout: stderr: open /opt/conda/lib/R/library/BH/include/boost/mpl/map/aux_/insert_impl.hpp: no space left on device
This container, from the dockerfile, is based on the
jupyter/scipy-notebook container. That particular container builds without issue. The volume on which containers are stored is fine for space with several TB free. I am guessing that this space issue is something to do with the configuration of Docker on the NAS device and some part of how it creates container images. For instance, like a /var running out of space etc.
The NAS is a TVS-882 with the i5-6500, 16GB RAM, running QTS 4.2.2 (2-11-2016) and Container Station 1.6.1709 which seems to have Docker version 1.11.2, build 3a84010.
If anyone can advise that would be great, especially if there is a command line workaround to build the image that cannot be replicated in the web UI.
TS-439 Pro running Debian Stretch, TVS-882 running QTS.
