Does anyone have general recommendations for settings to use with VMware vSphere 6.x?
This document has some general (older) guidelines....
http://files.qnap.com/news/pressresourc ... _above.pdf
Specific questions:
1) Should the recycle bin be enabled or disabled?
2) What is the impact of the Media Folder option being enabled?
Thanks,
Steve
NFS Share settings recommendations for use with VMware vSphere
Re: NFS Share settings recommendations for use with VMware vSphere
Disabledstappmeyer01 wrote:1) Should the recycle bin be enabled or disabled?
Probably has no effect, but I would disable in any case.stappmeyer01 wrote:2) What is the impact of the Media Folder option being enabled?
I also tried using NFSv4, but has some weird issues when trying to use vMotion to migrate disks between NAS's. Have stayed with NFSv3.
I created a separate volume for NFS on which I disabled caching, as that is the recommendation.
Primary: QNAP TS-h1283XU-RP w/ 10 x Seagate EXOS 16TB in RAID-TP
FW QuTS Hero H5.0.0.1949 / 32 GB ECC RAM / Built-in 10 Gig network
Backup #1: Synology RS3617XS+ w/ 10 x Hitachi Ultrastar 10TB in RAID 6
FW DSM 7.0.1-42218 Update 3 1 / 8 GB ECC RAM / Built-in 10 Gig network
Backup #2: QNAP TVS-863 w/ 8 x Hitachi Deskstar 6TB in RAID 6
FW 5.0.0 / 8 GB RAM / LAN-10G2T-X550
Ternary: 2 x QNAP TS-879U-RP w/ 8 x WDC Red 4TB in RAID 6
FW 4.3.6 / 32 GB ECC RAM /
Ternary: QNAP TS-470 Pro w/ 4 x WDC Red 4TB in RAID 6
FW 4.3.6 / 16 GB ECC RAM /
- storageman
Any reason not to consider ISCSI?
