I use a TS-853A NAS to mount a Windows Server 2016 test cluster. When I make copies on a volume in ISCSI (which is not set in Shared Volume) speeds are very good about 800MB/s.
As soon as I switch it to Shared Volume the speed drops to 10MB/s.
When I run the tests under a Windows Server 2012 R2 cluster the speeds remain stable at 800MB/s
What can I do to solve this speed problem in Windows Server 2016?
I made the configuration according to this document: http://files.qnap.com/news/pressresourc ... g_MPIO.pdf
ISCSI Shared Volume in Windows Server 2016 Very Slow
Re: ISCSI Shared Volume in Windows Server 2016 Very Slow
I have the exact same problem, very slow in cluster, quick none cluster.
Please Qnap help us
Lancia did you fix the problem?
if you want qnap to help .. contact them
this is a user forum
- storageman
How does an 853A achieve 800MB/s? Not possible...
