Can't Select CD Image/ISO
Attempting to in stall a new Win 10 VM, every time I select an ISO I get the following error:
Specify a name that does not contain the following characters...
I have renamed the ISO multiple times without any special characters and tried other ISO, same errors, any ideas?
- Don
Re: Can't Select CD Image/ISO
Insufficient information provided.
NAS model? NAS firmware version? ISO file name including full path? VS version? Full error message?
my bet would be also on the full path name
\\NAS\^^%109209";/.;[]\iso.iso will probably not work
- Don
I just tried building a Win 10 VM and got the same error message. The file name was "Win 10 pro.iso". The error message clearly states that the path and file name cannot contain whitespace. I copied the file to the public folder (no spaces) and removed the spaces from the file name (Win10pro.iso) and it worked fine.
Hi get the same error messages on my TS-453A : Specify a name that does not contain the following characters: ` * = + [ ] \ | ; : ' " , < > / ? % whitespace
Except !!! I do have also a TS-253A and in that system it still works fine.
Specifications:
TS-453A:
RAID 5 4x3 TB
Memory 16 GB
TS-253A:
RAID 0 2x3 TB
Memory 16 GB.
Both systems due have a virtual switch and I am also using a physical switch, with VLAN tagging etc.
Last but not least 2 physical firewalls : Check Point and Palo Alto
Everything worked fine, TILL the firmware upgrade...
Greetz Marco
The Netherlands
Specifications:
TS-453A:
RAID 5 4x3 TB
Memory 16 GB
TS-253A:
RAID 0 2x3 TB
Memory 16 GB.
Greetz Marco
The Netherlands
- Don
How about answering the questions asked a few posts back.
NAS model? (provided) NAS firmware version? ISO file name including full path? VS version? Full error message? (provided)
Hello
I get the same error messages on my TS-251 : Specify a name that does not contain the following characters: ` * = + [ ] \ | ; : ' " , < > / ? % whitespace
TS- 251
Firmware - 4.3.3.0210
RAM - 8 GB
TS- 251
RAM - 8 GB
TS-251 - Intel 8GB , 2 x 3 TB TOSHIBA DT01ACA300 , Firmware 4.3
TS-220 ARM, 2 x 3 TB TOSHIBA DT01ACA300 , Firmware 4.2
http://www.oben.pl
http://www.oben.pl
did you see Don's answer regarding posting full path and filename ?
- Don
I give up. Since no one is willing to provide the information requested please open a ticket with QNAP.
I too am receiving the same error, did qnap support provide a fix?
Didn't encounter this issue until upgrading to QTS 4.3.3
TVS882
TVS882
- Don
Unable to assist since no one seems fit to post the requested information.
Problem solved. An error occurs when the access path is in a subfolder. Moving image.iso to the Public folder resolves the issue.
http://www.oben.pl
http://www.oben.pl
It seems, since the update to Virtual Station 3 this issue has occurred. Also you can create backup jobs now unless you remove all your VM's and create a new Share (sharename without any spaces e.g. VirtualMachines/VM) and this import them back into VS3.
QNAP Strikes again!!!!
- joelang1699
- Easy as a breeze
Same issue
TS-EC1080 Fw 4.3.3.0262 Build 20170727
Regards
Joe
TVS-EC1080 32Gb Ram 10x WD60EFRX Raid 6
TS-1079 Pro 16Gb Ram 10x WD60EFRX Raid 6
TS-879 Pro 2Gb Ram 3 X WD60EFRX Raid 5
TVS-863 4Gb Ram 3 X WD60EFRX Raid 5
Joe
- Trexx
VS changed the naming standards to no longer allow spaces. You can replace them with _'s
Paul
UPS: CP AVR1350
UPS: CP AVR1350
