Poor VM Performance
Poor VM Performance
1 vm, 4GB RAM, 2 cores on a new T-453A. I am the only user of the qnap and this is its only role aside from file server. Performance is slow, almost reminds me of dial up with pcanywhere from the early 90's. Well maybe not that bad.
It is a Windows 10 professional vm, all MS updates. Only two softwares installed. Quicken personal finance software, and teamviewer for remote access. After installing and updating windows, I mounted the tools and ran the install. My question to all, if my QTS and Virtualization Station was up to date did I install the latest tools? Is there anything else folks do to increase performance?
Thank you all for any suggestions,
Ryan
Ryan
- Toxic17
Re: Poor VM Performance
I take is your using the virtio drivers?
https://www.qnap.com/en-uk/how-to/tutor ... on-station
viewtopic.php?t=130522
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Qnap Downloads
- Trexx
The "Guest Tools" version that QNAP bundles with VS, will NOT be the latest version as referenced in my Tutorial linked above. I generally haven't had any issues using the latest VirtIO drivers EXCEPT on occasion the QXL driver. The rest of them have installed fine.Ryan77 wrote: My question to all, if my QTS and Virtualization Station was up to date did I install the latest tools? Is there anything else folks do to increase performance?
A couple things to keep in mind, you are working on a celeron class processor in your QNAP. Works great for QNAP functions, but it is limited in horsepower for running VM"s, so even with everything configured right... it still won't be "Speedy"
Secondly, I wouldn't use Teamviewer for remote access (unless you are WAN remote), enable RDP access and use RDP client. Works much better. Other options are SPICE or VNC client, but I tend to stick with RDP access.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
Thank you Paul for the quick reply. I will review you tutorial in detail tonight.
The performance is about the same using team viewer or RDP on the same network plugged into the same Gig Switch. I will try your suggestions away from team viewer.
I upgraded to this T-453 with 8GB of RAM from another QNAP specifically for virtualization station. I hope I am able to gain some performance, but now fear I may have wasted money and question why qnap would allow this software to run on this device. I would have bumped up to a larger unit but thought to my self its one small client VM doing one task running my quicken software, I am not looking to run multiple vm's so a more powerful system did not come to mind.
- Trexx
Feel free to post some screenshots of your VM config settings if you run into questions, etc.
Everyones definition of speedy is different, so without a "fact-based" reference point it is hard to argue right/wrong.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
I have a Win 2K16 Domain Controller setup and have been struggeling with performance for weeks. The system became so slow that I could enter a letter in the editor and then return some 5 minutes later to then eventually see it displayed.
Surfing the web I landed here and the pointers for the add in tools were helpful. However, I came across a well documented 'How To' which may help some of you guys out there:
How to Improve Performance of a QNAP VM Using Virtio Drivers: https://www.youtube.com/watch?v=UNvEaBGc73c .
I found a lot of effort was put into the very clearly explained solution shown.
Enjoy,
Enjoy,
If life was just black & white, we'd probably all be unemployed
- Moogle Stiltzkin
any rdp client you recommend?
is it possible to do audio via networking, or is the only solution to plug in speakers direct into the QNAP NAS?
also in regards to performance tweaks, is there anything besides the virtio do we need to setup ?
like in the vm settings hard drive, should we be enabling caching? because in the youtube the guy left that alone.
https://superuser.com/questions/32495/w ... rdp-vs-vncRDP is semantic. The RDP is aware of controls, fonts, and other similar graphical primitives. This means that when rendering a screen across a network, this information is used to compress the data stream significantly. For instance, if you know that this region of the screen if occupied by a button, with the color grey, then you don't need to send an image of the button across the network, but merely information such as location of this button, size and color.
VNC is "dumb" in this respect, and largely functions by sending the actual images across the network.
RDP is tightly coupled to the Windows platform whereas VNC is available for most platforms. RDP is also seen as far more performant than VNC, due to the semantic advantage.
I found some answers here
viewtopic.php?f=318&t=130522&p=600492&h ... ck#p600492
Last edited by Moogle Stiltzkin on Tue Jun 25, 2019 3:21 pm, edited 2 times in total.
NAS
Network
Resources
Network
Resources
what os are you running moogle ?
rdp clients should be a default install on most modern windows versions
I have audio via rdp .. but it can be hit or miss if it runs ok or crackles
- Moogle Stiltzkin
oops forgot to mention.
im using win10 64bit vm. 4 core, 8gb ram.
in the virtual station, the only option in UI was the vnc. I couldn't find a rdp. So i'm assuming the rdp trexx was talking about was the one in the VM itselfs, to enable that rdp?
https://www.groovypost.com/howto/setup- ... indows-10/
oo the default in windows 10? okay i'll check it out, thx i was assuming i need to install some third party client for it.rdp clients should be a default install on most modern windows versions
u got audio to work with rdp? then i need to get that working asap. oo... well if i can get it to work i'll post back if it's any different on my end.
*update
tried but couldn't get it to work. I'm trying to RDP over local lan, but must have missed a step or something
NAS
Network
Resources
Network
Resources
what users are allowed to connect to the rdp session?
or does not even connect to the user auth?
- Moogle Stiltzkin
i got it to work.
i enabled the rdp DEVELOPER initially.
after checking carefully, i enabled the regular rdp. It says "for other devices to connect, use this computer name".
So i then run the rdp client from the other machine (non vm) using that and it finds it. I just login with credentials then walah
comparing VNC to RDP.
First thing i notice was colors. colors looked much better in rdp. 2nd thing i tested was youtube. playback was much smoother no tearing. I didn't even install the nvidia graphics drivers or use the nvidia graphics card yet either (if i did i think i would be forced to plug in a hdmi monitor for it to be usable. i'll test that later )
i installed video player
https://www.videohelp.com/software/LAV-Filters-Megamix
had to use lowest setting (EVR). It's playable but at 1080p for a highbit rate 1080p video it will barely play. But if i resize the video player it plays fine. Bandwidth issue? that said i'm impressed it even worked.
*update
mpv seems to work much smoother even at maxed window resolution.
https://mpv.io
You mentioned clicking audio? but my audio works just fine, i don't notice any issues
i haven't tried gaming yet, but i'd rather do that with the nvidia graphics card hooked up and installed. on my to do list.
*update
okay i think i heard what you described. for me it was obvious during the windows 10 notification pop, theres a sound and it had a weird sort of crackling noise. Not too bad but it was quite transparent.
but during youtube and watching a video, the audio seemed fine. So if it's just gonna be one of those rare occurrences and not during listening to music or watching video etc, then i'm not too bothered by it.
Last edited by Moogle Stiltzkin on Tue Jun 25, 2019 8:35 pm, edited 1 time in total.
NAS
Network
Resources
Network
Resources
- Moogle Stiltzkin
one change in rdp i didn't like that worked before in VNC was this
In win10 start, you can type text and it will prompt the text shortcut. But i get instead in RDP a blank box. Any ideas how to fix that
other than that oddity, i'm pretty happy with rdp so far.
*update
ok i solved it. change the hard drive to use write through. Tbh i don't know if that is the best setting or not
https://www.computerweekly.com/feature/ ... -explained
*update
thats weird. i relogged into rdp, and notice the same issue again ...
*update
*update
NAS
Network
Resources
Network
Resources
never had this issue on rdp
one issue I have on some nvidia cards (quadro) is, the nview driver slows the gui down on rdp..unitstalling nview on driver update fixes that
- Moogle Stiltzkin
i may have figured out the black screen issue.
Windows 10 1903 Bug May Show Black Screen in Remote Desktop
i wonder could this be it? either way, rdp is acting wonky in the recent win10 builds so...
https://www.bleepingcomputer.com/news/m ... e-desktop/Microsoft has added a new bug to the list of known issues in Windows 10 1903 about Remote Desktop connections displaying a black screen when connecting to devices using older graphic drivers.
According to the bug report, when a user connects via Remote Desktop to device with certain older GPU drivers, including drivers the Intel 4 series of integrated GPUs, a black screen will be shown.
NAS
Network
Resources
Network
Resources
Before my now running TS-453Be I also used a TS-453A with 16GB RAM. There I had a working Windows 10 Ultimate which is running not very snappy via RDP. Before that I used Windows 7 which was running faster than Windows 10 and was snappy. What brought a little bit of speed was to let the VM ran from an external via USB 3 attached SSD. But QNAP stopped the Virtualization station working like this.
Now I am using a TS-453Be with 16GB RAM and a SATA M.2 SSD for the VM, which is now a 2019 Server Essentials. This is not very snappy. The 2016 Server before also was not snappy.
On this server only iTunes is running for my Apple TV, so I don't need the speed of the user interface of windows.
