Hi All,
I'm running a TS-1277 with NVIDIA Quattro P4000 GPU. On the VM I'm running Windows Server 2016.
On my first setup (without GPU pass through) VNC and RDP working fine.
After I add GPU VNC and RDP connection got refused. With a direct connected monitor, mouse and keyboard all is working.
NVIDIA drivers and tools from guest CD was installed.
When I remove GPU pass through VNC and RDP working again.
Any idea how to make RDP working with GPU pass through?
Frank
No VNC or RDP connection when GPU is active
Qnap TS-1277-1600-8G - CPU upgrade to Ryzen 7 1700 - RAM upgarde to 64GB
8 x 10TB Seagate IronWolfPro / 4 x 256GB Samsung 850 Pro / 2 x 240 GB Kingston SSDNow M.2
Intel X540-T2 / Nvidia Quadro P4000 (waiting for Plex HW decoding support )
- Trexx
Re: No VNC or RDP connection when GPU is active
VNC you would need to install a VNC Server within the VM to enable access to that with GPU. For RDP, just enable remote desktop support within Windows 2016.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
Hi Paul,
thanks for your answer but VNC and RDP are working fine as long as I not use GPU pass through.
I only stop the VM, add GPU and restart. Now VNC and RDP connections are not possible.
Cheers
Frank
Cheers
Frank
- Trexx
I understand... and I gave you the solution. I have an x77 and have used GPU VM's in VS as well. RDP works just fine on my win10 VM w/GPU.sEEbE wrote:Hi Paul,
Cheers
Frank
GPU Passthrough breaks the "built-in" VS vnc that was leveraging the SW based Graphics cards. WIth the GPU, you have to install VNC server (which is bundled as an option on the Guest Tools btw).
RDP works fine for me (I think I did have to enable it in WIn10 though initially).
Paul
UPS: CP AVR1350
UPS: CP AVR1350
Hi Paul,
again thank you for the fast response.
After GPU was enabled I connected a local display, mouse and keyboard. I installed the tools from the guest cd and disabled and enabled RDP.
But unfortunately I was not able to connect with vnc or rdp to the vm. Only local logins was possible.
After I removed the gpu I was able to connect again as before.
Cheers
Frank
Cheers
Frank
- Trexx
The VNC Server isn't part of the tools, but a separate option you have to select. I don't recall if you have to select custom install to be able to choose the option or not.
As for RDP, I would do some googling on that. Also make sure you are pointing at the WIndows 2016 IP address for your RDP connection and NOT the NAS IP address.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
Thanks for your help Paul.
I'll do some more tests after my business trip and come back with more information
Hi Paul, hi all,
after more tests I saw the core reason of the issue.
In my VM where the IP address was hard coded in the setup the add of the GPU changes the whole network setup and I got a different IP address.
After I set a new fix IP address all works fine.
Again for all: VM with GPU and the same VM without GPU have different network setup.
@Paul: thanks for your effort on this and sorry that I saw the network change so late.
Cheers Frank
Cheers Frank
- Trexx
No worries Frank. Glad you are up and running.sEEbE wrote:Hi Paul, hi all,
Cheers Frank
Paul
UPS: CP AVR1350
UPS: CP AVR1350
Very similar situation ("VNC or RDP connection when GPU is active") but in case with Linux VM
TVS-1282T3 (4.3.5.xxx), VM-CentOS7.3, GPU (1050ti/P2000).
CentOS 7.3 distro -Blackmagicdesign with Nvidia drivers.
1) If GPU switched on- connected monitor (via GPU's HDMI) + wired mouse and keyboard is fine. Davinci Resolve 15 rendering excellent. But no access via Virtualization Station, VNC, RDP.
2) If GPU switched off - No Davinci Resolve, but I have access via VS3, VNC etc.
