LACP between Cisco 3650 and QNAP
QNAP NAS solution for server virtualization and clustering/HA/FT
azeemhaider23
Post by azeemhaider23 »
Hello All
i am trying to configure LACP between Cisco switch 3650 QNAP NAS. on NAS side i have 2 Network port combined with IEEE 802.3ad on Cisco switch 2 ports configured LACP Active mode but there is message "LACP currently not enabled on the remote port." i tried both hashing (Layer 2+3 Mac+ IP, Layer 2 MAC)
any Idea how i can fix this issue.
storageman
Ask me anything
Re: LACP between Cisco 3650 and QNAP
Post by storageman »
azeemhaider23
Yes, i did select IEEE 802.3ad and i tried both hashing Layer 2 +3 Mac n IP and only Layer 2 MAC, but result is same.
storageman
Ask me anything
What Qnap model? I assume it supports IEEE
What firmware version?
Does basic trunking work?
https://www.qnap.com/en/how-to/tutorial ... -qnap-nas/
Also some SSH checking stuff here
viewtopic.php?t=128508
azeemhaider23
Model TS-659 Pro II
Firmware 4.2.6
with basic trunking which is Balance-alb i lost connection with NAS.
i connection was via IP address.
Toxic17
Ask me anything
Contact:
Post by Toxic17 »
I use LACP (Layer 2+3 Mac+ IP) on two of my NAS's and it works against a UniFi USW-16-150W.
maybe something misconfigured on the Cisco Side? are you using LACP for anything else on your Cisco switch?
Regards Simon
Qnap Downloads
MyQNap.Org Repository
azeemhaider23
yes i am using with couple of other Cisco switches. you can see PO6 gig1/0/31 is suspended.
Number of channel-groups in use: 6
Number of aggregators: 6
Group Port-channel Protocol Ports
1 Po1(SU) LACP Gi1/0/47(P) Gi1/0/48(P)
2 Po2(SU) LACP Gi1/0/45(P) Gi1/0/46(P)
3 Po3(SU) LACP Gi1/0/43(P) Gi1/0/44(P)
4 Po4(SD) LACP Gi1/0/41(D) Gi1/0/42(D)
5 Po5(SU) LACP Gi1/0/39(P) Gi1/0/40(P)
6 Po6(SU) LACP Gi1/0/31(s) Gi1/0/32(P)
here is configure on Cisco Switch
MDFMAIN#show running-config interface port-channel 6
Building configuration...
Current configuration : 106 bytes
interface Port-channel6
switchport access vlan 23
switchport mode access
switchport nonegotiate
end
MDFMAIN#show running-config interface gigabitEthernet 1/0/31
Current configuration : 187 bytes
interface GigabitEthernet1/0/31
description LINK BETWEEN THSNAS TO MDFMAIN
channel-group 6 mode active
end
MDFMAIN#show running-config interface gigabitEthernet 1/0/32
interface GigabitEthernet1/0/32
end
asm19
First post
Post by asm19 »
Hello azeemhaider23,
I have exactly the same problem between Cisco 9200L and QNAP TVS-1272XU-RP.
Works perfectly with the 4.4.0 Build 20190627 firmware and stops working on any of the latest ones.
How did you solve the problem?
On the switch ports I have: "suspended: LACP currently not enabled on the remote port."
Return to “Server Virtualization & Clustering”
