Suspend VM from Comand Line (or WebAPI)
QNAP NAS solution for server virtualization and clustering/HA/FT
knebb
Post by knebb »
is there any chance to suspend a running VM from command line? I would like to do a backup (and no, I do not want to use the QNAP-build-in tools).
So before backup starts I should logon through ssh, suspend the VM and once backup is done resume vm. What would be the commands to use there? I do not mind about ssh keys, all set so far.
Any ideas?
Thanks!
/KNEBB
dolbyman
Re: Suspend VM from Comand Line (or WebAPI)
Post by dolbyman »
see if you can find pointers here
viewtopic.php?t=90425
knebb
Post by knebb »
thanks, I was thinking of using virsh on my own. So it is safe to use it? The QNAP tools do not get confused by this?
Thanks!
/KNEBB
dolbyman
Post by dolbyman »
My guess is that is exactly what the GUI does .. just hidden via buttons and dropboxes
Return to “Server Virtualization & Clustering”
