Hi to all and sorry for my english,
I manage about 12VM in a cluster with:
2 x Host Esx 4.1.0.260247 on HP DL380G5 (single cpu and 16GB of RAM for any host)
1 x QNAP TS-459U
Both Esx use QNAP NFS share as shared storage.
All work fine but
- Some time vm user (terminal services) report some "tears" of some seconds. Terminal session "freeze" for some second and then restart. Different time in a day. Users in session in different VM report some issue.
- Snapshot usage for some VM is impracticable. If i delete a shapshot all VM in same node become unusable utill delete operation is completed.
We think that QNAP is in overload e we would upgrade it with new and more performance NAS. We think to QNAP TS-809U to use with iSCSI instead of NFS.
Is this a good point of start?
I can view "differences" whit this new NAS?
I hope to be clear.
Thanks in advanced for any help.
Massimo.
Infrasrtucture update - TS-459U
- schumaku
Re: Infrasrtucture update - TS-459U
Give you slightly more time - and consider the TS-879 Pro, TS-1079 Pro (ox enclosures) or the TS-1079U and TS-1279U in 19" enclosures becoming availane somewhat later. http://qnap.com/PressRelease_detail.asp?pr_id=241
I would not convert to a TS-809 anymore - unless there is fire under the roof.
Hi shumacu and thanks for your reply.
I have read article at link suggested, but i not found information about any date. Accordly with you i not change with TS-809 but how long will I wait for new models?
In any case, about "technical side" of the question? Upgrading storage is the best way to solve my problem?
Thanks.
Regards.
Massimo.
Thanks.
Regards.
Massimo.
- Easy as a breeze
NFS is a good fit for your environment, don't change it.lmassimo wrote:Hi to all and sorry for my english,
1 x QNAP TS-459U
All work fine but
I hope to be clear.
Massimo.
You haven't told us the number of disks, vendor/model and RAID config you run on your 459U
You may be interested in a free tool called VKernel StorageVIEW to identify datastore bottlenecks...
I wish I was a virtual machine!
VMware vExpert 2010, 2011 and 2012
Subscribe to my public Blog
Read my articles at VMware Planet v12n
Follow me on Twitter
How To Get wiper.sh Running On QNAP Storage Devices To TRIM SSDs?
What’s Best EXT3 or EXT4 For My NFS Datastores?
Chunk Size Of a RAID0 Volume On a QNAP NAS – What’s The Sweet Spot?
IOPS, RAID and Array Calculator/Estimator
One Of The Most Powerful Shuttle Barebone For My VMware Home Lab
Benchmark Tools – What I Use
How To Use QNAP NAS As A VMware Datastore Via NFS
Hi Pironet and thanks for your reply.
I have 3 disks WDC WD2003FYYS-02W0B01.0 configured in RAID 5. Is not good?
I look immediatly for tool you have suggested.
Thanks.
Massimo.
Thanks.
Massimo.
- Easy as a breeze
You have made a good choice there. These disk are Raid Edition and therefore fully compatible with TLER.lmassimo wrote:I have 3 disks WDC WD2003FYYS-02W0B01.0 configured in RAID 5. Is not good?
No you will have to look at the VMs and see which one generates high IOPS. Once you have found it you will have to fix it or throttle it to ensure it doesn't hog all your storage IOPS.
FYI in your current disk setup, high IOPS is anything bigger than 300 IOPS on a sustain rate.
You can have burst peaks higher that 300 but on a very short period of time (>20ms). Most of the time caches and queues will absorb and mitigate those bursts...
You may enable write cache for EXT4 but you should then install an UPS to protect your servers/storage devices.
I can use tool that you have suggested me or i can have another way to find this info?PiroNet wrote:No you will have to look at the VMs and see which one generates high IOPS
Sorry, did you min <20ms ? Or i have not undestrand...PiroNet wrote:You can have burst peaks higher that 300 but on a very short period of time (>20ms).
I have found suggestion about the number of HDD. I found suggestion about splitting (obviously in another storage such as TS-1079 Pro) in 8 or 10 HDD of (for instance) 600GB configured in RAID 5 can increase considerably the performance. With your knowledge can you confirm this? Making this type of upgrade i have a justified benefit?
Thanks another time for your help.
Regards.
Massimo.
- Easy as a breeze
Answers in bold
lmassimo wrote:I can use tool that you have suggested me or i can have another way to find this info?PiroNet wrote:No you will have to look at the VMs and see which one generates high IOPS
The tool can help you but there is no 'real' history, so you can go back and see the last 4 hours for example...
Use the vCenter Client to connect to either a vCenter server (if you have one) or directly to the ESX server and then look at the performance tab.
Oops, yes I meant <20ms
More you add spindles (disks) more you have IOPS to distribute among your virtual machines.
You could also go for SSD disks if the total IOPS required by your 12 virtual machines exceed by far 300 IOPS.
Or you throttle down the virtual machine that generates too much IOPS. Read more at Limiting Disk I/O From A Specific Virtual Machine
Regards.
Massimo.
