Hi all,
it's really an urgent problem because all my users are blocked from share folders.
System:
TVS-471U-RP
Version 4.2.4
I joined to an Active Directory, created necessary shares and everything was fine the last two weeks.
Yesterday I had troubles with virtualization station where a vm with debian / samba for active driectory was located.
I decided to reboot and to upgrade Firmware to newest version hoping to solve this - it didn't, so I went with the vm to another nas, where it started succesfully.
After rebooting TVS-471U-RP my shares where no more reachable.
I rejoined active directory domain again with success, but no AD-authentication possible.
If I try to create a new share, Domain Groups and Users are listed but I cannot set the rights for them.
In log I see after rejoining domain:
[Security Mode] Local user authentification selected for Microsoft Network
[Security Mode] LDAP authentfication disabled
[Security Mode] Join domain ... successfully
Error when setting permissions:
[Advanced Folder Permissions] ACL user/group not found; dom+Domain Admins, dom+Domain Users
I decided to downgrade to 4.2.4 again but it didn't have any effect.
Update:
In console I see that winbind fails:
/usr/local/samba/bin/wbinfo -t
could not obtain winbind interface details: WBC_ERR_WINBIND_NOT_AVAILABLE
could not obtain winbind domain name!
checking the trust secret for domain (null) via RPC calls failed
failed to call wbcCheckTrustCredentials: WBC_ERR_WINBIND_NOT_AVAILABLE
Could not check secret
What should I do?
Thanks,
Thomas
Domain Users cannot connect to share
Re: Domain Users cannot connect to share
Okay, I solved it.
It was my fault, I changed some permissions in some folders of /share/CACHEDEV1_DATA to a domain admin account, unfortunately also in /share/CACHEDEV1_DATA/.samba/
As long as samba was running winbind was fine with permissions (so I didn't notice my error), but of course not after reboot or restarting samba (unknown user Domain Admin ...).
I changed the permissions, now winbind works fine and everything looks okay; I will check other folders, too.
Thanks,
Thomas
Thanks,
Thomas
could you explain exactly what you did to fix this please?
We have the exact same symptoms, but i don't think I've altered any permission the folders in /share/CACHEDEV1_DATA/.samba/. . . well not on purpose anyways!
